Draggin Bagger Questions
Old Oct 15, 2006 | 11:39 AM
  #31
Bryan TTM's Avatar
Bryan TTM
Default RE: Draggin Bagger Questions
AMEE's good-lookin...glad i bought mine from her ...aint nothin wrong with a man making a profit...til he came out with his product none of yall researched it or did it...what DB did is pure American business
Old Oct 15, 2006 | 04:53 PM
  #32
2006ultra's Avatar
2006ultra
If I were DB I would switch to the Gabriels. The shock is twice the quality for the same money. The boot is concealed, the shock is heavier and the air mounts are better built. I wouldn't ride on the moroe's after I tested them. JUNK! JMO
Old Oct 15, 2006 | 05:29 PM
  #33
lacedwheels's Avatar
lacedwheels
Hay 2006ultra, Do you have the part # for the Gabriels that you installed?
Old Oct 15, 2006 | 05:32 PM
  #34
Jerry L's Avatar
Jerry L
ORIGINAL: Gaskett
Did my own system. I used a different pump (mounted under the battery). I also mounted my own switch inside the left hand turn signal mount. That way I can use my thumb to actuate the pump or the air relief solenoid. All the parts were $165.00 and it took a few hours to install.
Glenn
Hey, Glenn. Got any pics of your handlebar switch location? Wonder if I could use the radio button on the left side, never use it anyhow.
Jerry
Old Oct 15, 2006 | 05:44 PM
  #35
2006ultra's Avatar
2006ultra
ORIGINAL: lacedwheels
Hello, I'm not at home right now but if you go to Gabriels website and compare off of the monroe MA785 number you will find them. There is two numbers for the shocks. The only difference is one set comes with all the fittings. I just searched it and came up with 39504 thats the number without the fittings 49304 is with the fittings. Thats what you want.
Old Oct 15, 2006 | 07:02 PM
  #36
lacedwheels
Thanks much 2006
Old Oct 16, 2006 | 10:39 AM
  #37
2buxleft's Avatar
2buxleft
2006ultra....... what kind of relief valve did you use.......part numbers ? Been doing some research and can't seem to find a suitable valve. Any direction as to where to find one ????
Old Oct 16, 2006 | 11:42 AM
  #38
2006ultra's Avatar
2006ultra
I used a relief valve from a Rancho 9000 shock kit I have on my Jeep. It's basically a valve stem with a button screwed on that you push to release the air. Real simple but effective.
Old Oct 16, 2006 | 07:22 PM
  #39
Gaskett's Avatar
Gaskett
Jerry,
Here's the pic of the switch mounted in the turn signal housing. It's momentary 3 position switch. Push to one side and air pump comes on, push to the othe side dump solenoid opens.
Glenn
[IMG]local://upfiles/8572/D7ADB96256EB4C0BBCC99AF93AAB1605.jpg[/IMG]
Old Oct 16, 2006 | 07:26 PM
  #40
lp's Avatar
lp
Since you've been in there... would a small three way toggle switch fit in the same place?
Thanks.
lp
