Draggin Bagger Questions
Old Oct 16, 2006 | 09:19 PM
  #41
Jerry L's Avatar
Jerry L
Default RE: Draggin Bagger Questions
ORIGINAL: Gaskett
Jerry,
Here's the pic of the switch mounted in the turn signal housing. It's momentary 3 position switch. Push to one side and air pump comes on, push to the othe side dump solenoid opens.
Glenn
[IMG]local://upfiles/8572/D7ADB96256EB4C0BBCC99AF93AAB1605.jpg[/IMG]
Thanks, Glenn. That's got some marbles rolling around in my noggin! LOL.
Jerry
Old Oct 16, 2006 | 09:25 PM
  #42
Primo's Avatar
Primo
Hey you DB guys:
Just a quick question: Does the valve on DB's system bleed off back at the compressor when you toggle to lower the bike?
Just wondering since my setup is different and bleeds out of the dump button itself.
Not better, not worse. Just different.
Primo
Old Oct 16, 2006 | 09:27 PM
  #43
Primo's Avatar
Primo
Primo
  #44
kdietz's Avatar
kdietz
ORIGINAL: Primo
Hey you DB guys:
Primo
Bleeds out of the valve....where ever it's mounted
Old Oct 16, 2006 | 09:30 PM
  #45
Primo's Avatar
Primo
ORIGINAL: kdietz
ORIGINAL: Primo
Hey you DB guys:
Primo
Thanks. I was just wondering.
Primo
Old Oct 16, 2006 | 09:32 PM
  #46
Gaskett's Avatar
Gaskett
lp,
It's pretty tight inside there, that's the reason I had to make that spacer (the silver part). The spacer is machined out of 316 stainless, this was need to move the switch out to make room for the wires inside the turn signal housing. I'm contemplating making an entire new housing that would mount below the radio control button. Basicaly extend the housing downward and have the button mounted on the front. That will be a rainy day project.
Glenn
Old Oct 16, 2006 | 11:53 PM
  #47
lp's Avatar
lp
Sounds good. Thats the best place for it anyway if you ask me. Well done.
lp
ORIGINAL: Gaskett
lp,
Glenn
Diehappy
Nov 9, 2017 10:59 AM
dets97
Apr 27, 2012 11:26 AM
JMynes
Mar 13, 2007 10:49 AM
Gaskett
Jan 6, 2007 11:19 PM
WISHBONE
Nov 27, 2006 11:36 AM
