Sensor in exhaust
Old Mar 20, 2011 | 11:28 AM
duck1976's Avatar
duck1976
Stage IV
Default Sensor in exhaust
what is the sensor in the crossover tube for in my 08 ultra and can it be removed ?
Old Mar 20, 2011 | 11:34 AM
DrPlastic's Avatar
DrPlastic
It is an O2 sensor for the computer. Only way to remove it is to install an aftermarket tuner . My PC-V has you disconnect it as it is not used. some systems replace the narrow band sensor with a wide band sensor such as the auto tune add on for the PC-V.
Old Mar 20, 2011 | 11:40 AM
duck1976's Avatar
duck1976
Stage IV
on my o5 road king i welded a plug in the crossover to make it tru duals- can it be done on the 08 ultra then put the sensor back in ?
Old Mar 20, 2011 | 11:43 AM
dawg's Avatar
dawg
Once you have duals on it (homemade or other) you should have a tuner of some sort anyway.
Old Mar 20, 2011 | 11:47 AM
duck1976's Avatar
duck1976
Stage IV
suggestions on aftermarket tuner?
Old Mar 20, 2011 | 11:55 AM
dawg's Avatar
dawg
Depends on what you want to pay. There is the Dynojet PCV, Dynojet Powervision, TTS Mastertune, etc. I personally like and run the TTS Mastertune. The Dynojet Powervision is supposed to be a real good choice as well. What other mods have you done? Air cleaner, etc?
Old Mar 20, 2011 | 11:58 AM
duck1976's Avatar
duck1976
Stage IV
this is the start - where do i go from here?
Old Mar 20, 2011 | 12:02 PM
DrPlastic's Avatar
DrPlastic
My choice is the Dyno Jet PC-V with the Auto-tune or PowerVision system!
Old Mar 20, 2011 | 12:25 PM
dawg's Avatar
dawg
Sky's the limit. If you simply want a stage 1, then get an air cleaner set up like SE, Arlen Ness Big Sucker, Doherty, etc., put on a decent set of slip ons after you make your duals (or buy an aftermarket set of duals or 2-1, etc.) and a tuner. If you want more, you can do cams. If you want more, you can bump it up to 103 or higher, if you want more you can have headwork done. It all boils down to your riding style and what you're looking to accomplish. As well, make sure all parts compliment each other.
Old Mar 20, 2011 | 12:27 PM
dawg's Avatar
dawg
For now on my 08 Ultra I have 575 cams, SE air cleaner, 2-1 exhaust, TTS Mastertune and changed the gearing with the 49 tooth ring gear conversion. I will soon be bumping it up to a 103 with no headwork and leave it at that for quite some time. Right now it pulls great and does what I want it to. Wife and I and loaded with luggage and it runs great.
HardyHarHarley
May 18, 2023 04:14 PM
Brunster11
Mar 29, 2015 11:17 AM
flyer91
Aug 28, 2010 04:21 PM
shrini23
Oct 7, 2009 10:34 PM
JekyllnHyde
Aug 11, 2009 05:34 PM
