Power Commander Problems
Old Apr 26, 2011 | 04:06 PM
  #41
n8dc's Avatar
n8dc
Originally Posted by IAMSWUTIAMS
A dyno tune for just an air cleaner seems like overkill. But good for you.
If thats what he wants then I say go for it
Old Apr 26, 2011 | 06:40 PM
  #42
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Originally Posted by White Ice
Man, this place really really really needs a SARCASM smiley.
It would be helpful at times.
Old Apr 27, 2011 | 08:47 AM
  #43
XSKIPRO's Avatar
XSKIPRO
With the air cleaner I got an increase from 58 HP to 63 HP and BLUE PIPES! Too much air not enough fuel = lean mixture which = BLUE PIPES
With the a custom fuel map I got to 72 HP and now the pipes stay chrome, no more bluing.
I'd say it was worth it but then again some prefer to clean their pipes after every ride!
Old Apr 27, 2011 | 08:55 AM
  #44
sageone's Avatar
sageone
You gained 14 HP by adding nothing more than an air cleaner? That's how I interpreted it. I thought the post about the air cleaner and the tune was with the poster adding only an air cleaner and nothing else (no pipes).
Old Apr 27, 2011 | 09:05 AM
  #45
XSKIPRO's Avatar
XSKIPRO
SE A/C and a PCIII with custom Dyno Tune to create a custom fuel map.
Not just Air Cleaner...
SE kit with K&N $130
PCIII $400
Professional Dyno To and Map $260
Old Apr 27, 2011 | 09:11 AM
  #46
sageone's Avatar
sageone
Yes, that's what I meant. An air cleaner and a tune (map and dyno) and you gained 14 HP? The mufflers and headpipe are stock, correct?
Old Apr 27, 2011 | 09:48 AM
  #47
IAMSWUTIAMS
Wow, that's pretty good for just an a/c. But then again, a Dyno guy can create whatever numbers he wants to impress the customer.
Old Apr 27, 2011 | 09:56 AM
  #48
XSKIPRO's Avatar
XSKIPRO
Yes they are stock,
58 HP is the published HP for my 2002 FLHTCI
I Saw the dyno runs and watched the process. Not sure how Bruce could have made up the numbers that the dyno spit out but I guess it is possible.
A buddy of mine has an 03 FLHTCI and he has pipes but no A/C and he cant keep up with me.
Old Apr 28, 2011 | 06:21 AM
  #49
gregsdart's Avatar
gregsdart
I will add my .02 to back up his claim. I have a factory 103 limited. I have ac, se 255 cams, TTS tuner, and tried different combos to get the noise level to where i wanted it. For a while I ran the totally stock exhaust with the tuner, ac and cams installed. The bike still ran very well, and MUCH stronger than stock. No custom dyno tune either. Just a TTS map for the 255 cam. The torque was way up, Hp was way up. The last combo was going back to the Fuel moto Jackpot 3 1/2 inch dyno tuned mufflers with the quiet baffle, ac, cams, and TTS map. I give that credit for some more Hp on top of the already good results with the stock muffs and head pipe. All in all, my experience leads me to recommend an air cleaner/tune only for those who want a great gain and stock exhaust tone or noise level. It all seems to be in line with the $$ I spent on each item, with one exception. Low speed torque didn't seem to be reduced with the stock exhaust.
Old Apr 28, 2011 | 06:38 AM
  #50
sageone's Avatar
sageone
That's great. Did u gain 14 HP with just an AC and a tune? Not seat of the pants, but actual numbers.
