Power Commander Problems
Old Mar 30, 2011 | 12:32 PM
iclick's Avatar
iclick
*** Deleted double post ***
Old Mar 30, 2011 | 12:33 PM
iclick's Avatar
iclick
Originally Posted by mtaylor1111
What I have learned from this experience is buy from a company that has a good return policy. If you have any problems what so ever return it to them. The authorized retail company that I purchased the PC III from had 30 day return policy. Unfortunatly, I sent it back to DynoJet for testing during that period. So the retailer says that I went beyond 30 days so no refund.
Fuel Moto also gives a double warranty on PC's and PV's, which is two years. If it goes bad, which is very unlikely, they will deal with it themselves. They may also extend warranties of other tuner products too, so if interested I would ask.
BBStacker's Avatar
BBStacker
Originally Posted by Turbo Turtle
I recently ran into a pretty smart feller who had just gone through a HD factory dyno school. He sez that HD factory school informed the class that any and all piggy-back tuners were eventually going to trash your ECM. So just use what the factory provided and get a Dyno tune. No more , no less!
Good luck to any and all who chose to go with a aftermarket tuner
aka Bob
Would be interesting to see the statistics and what eventually occurs to the ECM. Friend of mine went to Harley School. We have talked about tuners and nothing was mentioned. Just did a little searching found this in an older thread on the forum.
this thread got my feathers a little ruffled, because it says a lot about the state of mind some stealers are in. has it come to a point where the average HD dealer can simply not be trusted? i e mailed power commander tech support last night, this is what was said:
https://www.hdforums.com/forum/elect...-warranty.html
Quote:
Hello,
I have a 2004 Harley Davidson Road King Classic. I am running a stage 1 air
cleaner, Reinhart true duals and a PowercommanderIII USB. I am hearing
several people claim that the use of the power commander voids my warranty,
and that I can expect the powercommander to cause my ECU to fail. I don't
buy it, but I would like to hear your take on this situation. I have used
powercommanders on sportbikes, and never had a problem. Thank you for your
help in this matter,
Sascha Krumnow
Quote:
Sascha,
This is absolutely not true. This is usually a scare tactic used to get you
to buy something else. The Power Commander cannot void your warranty, unless
it damages the bike and the manufacturer can prove it. There are laws
against this. The Power Commander is incapable of damaging the bike as it
sends no current to the bike/ECM. All it does is intercept the injector
pulse width signal (a ground) and fire the injectors (by grounding them). It
is basically a really fast, accurate ground. It does not generate current.
If you have any questions, I would be happy to answer them, or feel free to
call our tech line at 800-992-4993.
For warranty protection laws, check out:
http://www.semasan.com/main/main.aspx?id=60128
Thanks,
Manny Hauswirth
Technical and Race Support
Dynojet Research
www.dynojet.com
800-992-4993
Decide for yourself.
Old Mar 30, 2011 | 01:10 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Some dealers have been passing around misinformation for years about what a Power Commander can or cannot do, however the fact of the matter is that it will not affect the ECM in any way. There are literally hundreds of thousands of PC equipped bikes on the road and in my 10 years of working with the products all day, everyday I have yet to see a specific example of a PC induced ECM failure first hand.
As far as the OP's issue, there is very likely an issue with the PC harness. We have seen on early 818-511 08 Touring PC III's that the harness could be damaged very easily during the install. Dynojet will be able to diagnose this or any other issue when they get the unit back.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Mar 30, 2011 | 04:15 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
So there!
Old Apr 25, 2011 | 05:39 PM
mtaylor1111's Avatar
mtaylor1111
6th Gear
Received a package from DynoJet today. Inside was a new replacement power commander for the old unit I was having problems with. Installed the new power commander and it works great. No problems idleing and my old maps work great. Thanks DynoJet for stepping up to the plate and replacing the old unit. Also, thanks to those that posted to this thread.
Old Apr 25, 2011 | 05:43 PM
n8dc's Avatar
n8dc
Humm I have on 06 glide classic with a PCIII usb and its fine ? Never a problem.
well great they got you all fixed up ........
Old Apr 25, 2011 | 05:55 PM
IAMSWUTIAMS
Great customer service for a great product.
Old Apr 25, 2011 | 06:38 PM
GPHDXLC's Avatar
GPHDXLC
Thanks for the up-date.
Good to know they will stand behind their products.
Old Apr 25, 2011 | 08:15 PM
rdam's Avatar
rdam
aka Bob
How exactly does one "dyno tune" "what the factory provided" without an aftermarket tuner?
You know something we dont?
