Amsoil
Old Mar 24, 2011 | 08:09 AM
jkelley's Avatar
jkelley
I use it and all my friends do as well.
I think as indicated above that any of the major Syn oils are good for use.
Old Mar 24, 2011 | 08:10 AM
shortride's Avatar
shortride
I know the Amsoil Sever Gear oil sure make the transmission run more quiet.
Old Mar 24, 2011 | 08:37 AM
'05Train's Avatar
'05Train
I use Amsoil in the transmission (75W-140) and the crankcase. The stuff tests well, is reasonably priced, and I get it delivered to my door. The primary doesn't care for Amsoil ATF, so I use Drag Specialties Primary Fluid in there. I may try Formula + next change.
Old Mar 24, 2011 | 08:41 AM
soos's Avatar
soos
Old Mar 24, 2011 | 09:20 AM
MrMax's Avatar
MrMax
Originally Posted by Spur56
HD Syn3 is probably a pretty good oil, but it is made by the lowest bider for HD. Amsoil, Mobil, Redline, Royal Purple and many others are in the business of making lubrication products. There are many good synthetic oils out there and Syn 3 is probably in the lower half of the bunch. Having said that you can probably run Syn 3 and have no problems at all.
Pick one you like and that is easy to get a hold of and then ignore the rest of the oils threads you see. Mobil 1 15-50 is a great oil for the engine and is available at walmart and other auto parts stores.
+1
Amsoil, and or Mobil1 are the brands I use myself. The most important thing to remember is regular fluid changes, regardless of what type you decide to use.
Old Mar 24, 2011 | 09:29 AM
Ronp42's Avatar
Ronp42
Account Retired
I use Mobil 1 15W50 $6.77 a qt at Wally World. It's just as good if not better than Amsoil. I get less engine noise with Mobil 1. Advance Auto has Mobile 1 20W50 V-twin on sale. If you look at all the Amsoil test, Mobil 1 is usually somewhere near the top.
Old Mar 24, 2011 | 11:30 AM
hamnhog's Avatar
hamnhog
Cool Do what??
Originally Posted by lionsm13
amsoil is alright, more valve-train noise but it will cool your motor some.
It is actually mobil 1 syn with amsoil additives.
wrong
Old Mar 24, 2011 | 11:38 AM
thenewrage's Avatar
thenewrage
You can save money with amsoil if you go to their website and sign up to be a preferred customer. Its $20 a year but I saved that in one purchase because you get the oil at wholesale prices when you become either a preffered customer or a dealer. Just an FYI if anyone cares.
Old Mar 24, 2011 | 11:40 AM
nvsteve's Avatar
nvsteve
hamnhog Do what??
wrong
Actually, according to a very good source, linsm13 is not really wrong.
Amsoil buys their base stock from Mobil then adds their own additives.
Old Mar 24, 2011 | 11:41 AM
Buckinfitch's Avatar
Buckinfitch
Originally Posted by nvsteve
Agree with the above post. I use Amsoil but believe Mobil1 and Redline are just as good.
I use 1 quart of each ... no guessing
