12v outlet
Old Apr 2, 2011 | 03:38 PM
slhanks4's Avatar
slhanks4
Default 12v outlet
Having just purchased a new Ultra Limited, I was surprised to find no accessory outlet up front, in/around the fairing. I would like an outlet to power my GPS or MP3 player. This is my first HD and I am not familiar with the locations of the accessory connections or what is the best way to install such an outlet.
Old Apr 2, 2011 | 03:43 PM
nvsteve's Avatar
nvsteve
Look below the inner fairing on the left side. Should be a cigarette lighter there.
On the front of the radio there should be a 3mm receptacle for your mp3.
Old Apr 2, 2011 | 03:50 PM
Flintshooter54's Avatar
Flintshooter54
Here is the thread on how I hooked mine up. Page two I added pictures.
https://www.hdforums.com/forum/touri...use-block.html
Old Apr 3, 2011 | 12:32 AM
slhanks4's Avatar
slhanks4
Hey, thanks! I found it beneath the handlebar, just to the left of the fork. I hadn't noticed it and the tech that did my walk through apparently didn't know it was there. He told me the only outlet was in the tourpak.
Old Apr 3, 2011 | 06:04 AM
Blue Duck's Avatar
Blue Duck
Although it can be used, Harley does not recommend using it as an accessory plug. I used mine for my GPS and wound up blowing the fuse. If that happens you will lose your heated grips as they are on the same circuit.
Old Apr 3, 2011 | 06:55 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Been using mine for my Garmin GPS for two years and never blew any fuses. It may depend on what type of charger your using for the GPS. If it's the one that came with the GPS there should not be any issues, if you use a cheapo e-bay type charger it may cause issues. That's been my experience anyway.
Old Apr 3, 2011 | 07:01 AM
AnotherBlackSG's Avatar
AnotherBlackSG
Yeah, the manual says not to use it for anything but a cigarette lighter so, I spoke to my dealer. He said that the manual says that for liability reasons, but that he knows MANY people who do and don't have any problems. I've used mine for GPS ever since and have never blown a fuse or had any problems with it.
Old Apr 3, 2011 | 07:16 AM
nvsteve's Avatar
nvsteve
I've used mine to power a 12 volt compressor with no issues. Also for a GPS.
Old Apr 3, 2011 | 08:02 AM
mastery's Avatar
mastery
Have used mine for years with a GPS, never blew the fuse. Ya probably either used an aftermarket junk charger, or had a different issue. Regardless, spare fuses should always be carried on the bike...you can blow a fuse for many different reasons, and always at the worst possible time.
Old Apr 3, 2011 | 08:31 AM
cdestuck's Avatar
cdestuck
As to the usage...trust me, a GPS has much less draw than a lighter. Never had a problem with my GPS.
