street glide grip replacement?
Old Apr 6, 2011 | 07:46 PM
powerman1972's Avatar
powerman1972
Default street glide grip replacement?
Any tricks on replacing the handlebar grips on a 2011 street glide with the electronic throttle do-hickey? thanks in advance!
Old Apr 6, 2011 | 08:27 PM
drukanfu's Avatar
drukanfu
It's usually the best to jerk off first, then yer more relaxed and have more hand strength to remove them.......maybe practice some first.
Old Apr 6, 2011 | 08:32 PM
hockey8787's Avatar
hockey8787
they are a piece of cake!! just loosen the two torx bolts wide enough to slide the old off and then slide the new on 10 minute job
Old Apr 6, 2011 | 08:43 PM
luc.who's Avatar
luc.who
the kury web site use to have a video on this. I looked for it but it looks like they removed it. I recommend getting the manual. What I remember from this is you need to put something in the front brake lever to keep from damaging the brake lite switch.
Old Apr 6, 2011 | 09:09 PM
Slacker8's Avatar
Slacker8
Like Hockey said it's a 10 minute job. See this link for instructions.
Old Apr 6, 2011 | 09:43 PM
Phat09flhx's Avatar
Phat09flhx
Cut the left one off, the right side just loosen the 4 torx screws and pull the grip out and off. More than likely you'll have to adjust the controls on the throttle side any how since most grips are longer than stock. Adjust the controls so that the throttle will return on its own and tighten everything up. Oh and you may have to the controls on the left as well.
Old Apr 6, 2011 | 11:54 PM
Potato_Potato's Avatar
Potato_Potato
It is much easier than cable throttle bikes. Just follow the instructions.
Old Apr 7, 2011 | 12:28 PM
powerman1972
Thanks for the replies fellas! And drukanfu, sounds like you beat your meat quite often!
Old Apr 8, 2011 | 01:19 AM
JohnScrip's Avatar
JohnScrip
Mount the throttle first -- You're limited in motion with that one. Then make the left match the right.
dpfam5
Dec 29, 2013 06:24 PM
harleylay
May 20, 2012 08:37 AM
CYCLE
Apr 9, 2011 01:09 PM
sanlyn
Aug 11, 2010 08:39 AM
first dyna 07
Aug 3, 2007 02:25 PM
