2002 electra glide chirping
Old Apr 11, 2011 | 05:23 PM
auto8100's Avatar
auto8100
Stage I
Default 2002 electra glide chirping
My 2002 ultra has a chirping noise when I lift off the throttle, more in 3,4,5 gears, it goes away as soon as I pull the clutch in, or get back on the throttle, tighten belt, tightened and lubed muffler clamps and mounts, still chirping.
Old Apr 11, 2011 | 08:18 PM
Notgrownup's Avatar
Notgrownup
Spray some belt dressing on the drive belt....Make sure it's tight enough....
Old Apr 11, 2011 | 08:42 PM
Potato_Potato's Avatar
Potato_Potato
Spray some lube on the rubber saddle bag supports. If it goes away you found it. To fix it you can swap the rubber pieces from side to side or get new ones. Sometimes just loosening up the mounts and retightening will fix it.
Old Apr 11, 2011 | 09:13 PM
jmacdonald5's Avatar
jmacdonald5
most likely it's the belt...to tight will do it
Old Apr 12, 2011 | 07:58 PM
2002EGlide's Avatar
2002EGlide
Mine had the same issue. It turned out to be the drive belt. Mine was loose and a quick tighten fixed it.
Good Luck.
HOGILAC
Wheels/Tires
Jan 4, 2016 08:29 AM
BikerOptix
Aug 18, 2012 10:36 AM
Kirbybell
Jul 16, 2012 04:26 AM
Rem
General Topics/Tech Tips
Oct 31, 2006 08:26 PM
LuckyRoadKing
17
Aug 15, 2006 06:26 PM
