Accessory Power Point Locations
Old Apr 15, 2011 | 04:58 PM
TickTock's Avatar
TickTock
Default Accessory Power Point Locations
Are there any other accessory power point locations other than the one under the seat - like maybe in the fairing? I have a 2011 EGC
Old Apr 15, 2011 | 05:04 PM
Copyless's Avatar
Copyless
Like the cig lighter, on the lower left part of the fairing? If not that one, you can get one and mount it in the trunk. I guess this is the type of power point you are looking for?
Old Apr 15, 2011 | 05:08 PM
TickTock's Avatar
TickTock
Under the seat there is one with a connector already attached - I assume for heated gloves or something. I am looking for that type.
Old Apr 16, 2011 | 05:36 AM
Joltergeist's Avatar
Joltergeist
I also have a '11 FLHTC, there are 2 that I know of... under the seat (Mine's already dangling out for quick access) and the other is in the Tour Pack. I've ordered a lighter dongle for that one, and use the lighter plug in the fairing for the power for my GPS and iPhone.
Old Apr 16, 2011 | 09:18 AM
Copyless's Avatar
Copyless
It might be easier if I knew what you are trying to connect or where, I say this because if it is something in the fairing (you did mention the fairing), then there is a connection on the headlight harness, it uses spade connectors. If this connection happens to be used (normally not) you can add #70459-05 / 70458-05 which is a Y-connector for another spot.
If in the trunk, as Jolter said there is one there also, for lights or other acc., like the Aux Power Port #91671-10. The one I believe you are speaking of under the seat area, although can be used for other things, is actually put there for a battery tender.
XLRG
Feb 24, 2019 04:47 PM
Lilman
2014-2024 Touring Models
Sep 30, 2015 01:54 PM
Garemlin
Sep 9, 2012 05:16 PM
jerryleejr
Sep 9, 2012 07:44 AM
creep1
Aug 14, 2008 05:52 PM
