120R as a touring platform?
Or he could invite the public in to work with the mechanics and learn how to do the jobs and make the money off the parts and gaskets.
They serve lunch and get a good reputation from there customers.
My guess is you work for Harley.
19220-12 120R crate motor $5,695.95 $4879.58
27713-08 High Flow 58MM EFI Throttle Body $429.95 $353.96
27796-08 HIGH FLOW INJECTOR KIT $139.95 $111.96
37951-98 CLUTCH DIAPHRAGM SPRING $29.95 $23.96
37976--08A KIT-CLUTCH RACE $249.95 $199.96
37980-10 PERFORMANCE CLUTCH PLATES $169.95 $135.96
Total $xxxx.xx $5705.38
Note: There will more than likely be an additional shipping charge for the motor, and the part number plieski gave is showing the motor is a “120R”…”A model”, so you would want to verify they’re sending the Touring engine.
Damn, I just might do this. Of course a couple hours on the Dyno at Speeds Peformance Plus would be required, and I'd lose a few horses because I like my pipes.
Scared to death of that damn crank with these kind of power levels, though.
~Joe
Note: There will more than likely be an additional shipping charge for the motor, and the part number plieski gave is showing the motor is a 120R A model, so you would want to verify theyre sending the Touring engine.
~Joe
When I got the same quote it was $255.00 shipped to commercial address
You won't be able to wipe the **** eatin grin off your face for a month after putting in that 120. Going big was the best/funnest decision I've made in a while. Well worth it.
