Air Cleaner dripping Oil???
Old Apr 24, 2011 | 04:20 PM
fettnersa's Avatar
fettnersa
Angry Air Cleaner dripping Oil???
I have a Screamin Eagle Stage 1 chrome backplate with K&N Filter and I can't seem to avoid oil from dripping or blowing back onto the exhaust pipes. I've tried running 1/2 quart low and using less air filter oil but the problem is still there. Is there a better air cleaner system that will eliminate this problem? Seems like the excess blow by should end up in the throttle body intake but I can watch it come out of the small return holes and drip right down to the bottom of the air filter. After it collects in the filter it starts dripping. I don't really want to drill larger holes or run tubes to the ground. Has to be a system that works.
Old Apr 24, 2011 | 04:26 PM
dawg's Avatar
dawg
I always drill my rocker supports larger for better oil return and I drill and tap my backing plate, plug the stock holes and reroute the breathers via rubber line to the ground.
Old Apr 24, 2011 | 04:34 PM
redclamchowder's Avatar
redclamchowder
Have the same problem but since I am getting some stuff done at the shop, I am having exactly what Dawg posted done. I usually have a bit of oil on my right saddlebag when I stop after a long ride...somehow though, its never on my leg...go figure.
Old Apr 24, 2011 | 05:05 PM
CigarCritic's Avatar
CigarCritic
The HD Heavy Breather is the only one that has never leaked on me. I prefer the looks of the Ventilator but it drips constantly.
Another solution is to ride the bike like grandpa and keep the rpm's low.
Old Apr 24, 2011 | 05:08 PM
lionsm13's Avatar
lionsm13
You would think that as much $$$ that we spend on our bikes that the moco could do this right to where they do not leak?
Old Apr 24, 2011 | 05:11 PM
CigarCritic
Yep, 1930's technology.
Old Apr 24, 2011 | 05:12 PM
lp's Avatar
lp
I don't understand why someone does not just drill and vent the valve covers up where it would be hidden by the tank and block those stinking holes heading to the intake. I'm about to buy a set of take offs on ebay and do it myself.
lp
TWIN CAM 96's Avatar
TWIN CAM 96
You put to much oil on the filter.
Old Apr 24, 2011 | 07:00 PM
natetp1227's Avatar
natetp1227
I had the same problem and is was after I cleaned the air cleaner the oil never fully dried. Is it engine oil or air filter oil? If it is engine oil it could be a dirty filter. There is also a set of umbrella valves that are plastic from harley. They makeaftermarket ones taht are metal and supposed to help. I had that problem on my '04 ECG.
Old Apr 24, 2011 | 07:15 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by fettnersa
...Seems like the excess blow by should end up in the throttle body intake but I can watch it come out of the small return holes and drip right down to the bottom of the air filter...
Those little vents actually emit a puff of oil-laden air. The oily mist shoots pretty much straight out and into the air cleaner. Once enough oil has accumulated at the bottom of the cleaner, it will begin to drip out.
I took two shorts pieces of steel brake line, bent them, and inserted them into each vent hole. They now direct the oily mist more directly into the intake.
I've also tried placing an oil absorbent padding between the bottom of the cleaner and plate catching much of the oil that drips.
Both methods seem to work pretty well. Of course, you could try some of the suggestions above and see what works best for you.
Hope that helps.
