2006 electra glide classic, no mods just slip ons. My problem is when i crack the throttle when moving the bike falls on its face and stalls out.
I pull over restart no problem. light throttle no problem, quick throttle is when the problem happens. fuel injected. 1353,1356 code only once when was trying to restart..????
Does it run like crap when cold?
If so , my brothers 06 did the same thing until he had the injectors changed, there was a service bulletin, or something about changing the injectors on the 06s.
thanks for the input,trying new plugs and wires first. checked all conections and grounds. heard that the system relay could also be an issue along with the injector issue. agian thanks
my 06 did something similar. checked and did all of those things, nothing. finally put a power comander on, and had it dynoed, bingo, ran, and still runs great. seems alot of the 06's were tuned really lean, and it sometimes manifests itself in that kind of performance. do something to rich it up abit and you'll really see a difference.
