Shifter Bushings
Old Mar 12, 2020 | 04:52 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I wanted surprised at what the replacement bushings were for my 04. The original ones in there were brass or bronze, the replacement were split steel.
I never did get them in, because I couldn't get the old ones out, at least not very easily. My collet type pullers couldn't get enough grasp on the thin walled bushings, they'd slip and come up inside the bushings, chewing the bushing up instead. Similar attempts to punch the bushings out. Didn't want to try using a saw to cut them, because I'd almost assuredly end up cutting the primary casing a bit.
Went with an o-ring in between the inner shift lever and the primary case, to take out the side to side slack, and that is working just fine at controlling the rattling.
I thought about drilling and tapping for a zerk fitting, but since it's just a quick job to release the inner shift lever and pull the shaft out to clean it and regrease it, I elected not to.
Old Mar 12, 2020 | 05:44 AM
GalvTexGuy's Avatar
GalvTexGuy
I looked up a 2014 Road King, which has the same chain case housing as your 2007 Road King. The part number for the bushing shows to be 42642-00A.
Old Mar 12, 2020 | 06:47 AM
Zerk's Avatar
Zerk
It is not uncommon to replace the linkage with one with better heim joints. Harley sells and upgraded and you see them on the internet. There has been few stories about them breaking at bad time. My 01 I replaced for hell of it, my 07 I had to
Old Mar 12, 2020 | 08:47 AM
HD Bobber's Avatar
HD Bobber
Reuse the stock linkage you have, trash the shitty Harley heim joints w/ the below chrome moly ones from Bung King. Had these on my Dyna and soon as I got my SG that’s the first thing I replaced! Love it and better shifter feel.
http://www.bungking.com/chrome-moly-heim-joint/
Old Mar 12, 2020 | 09:00 AM
Uncle Larry's Avatar
Uncle Larry
Yep, this works and it's a quick and easy fix !
hardheaded
Jan 28, 2019 03:21 PM
rkbagman
Milwaukee Eight (M8)
17
Jun 4, 2018 05:14 AM
kpb46
2014-2024 Touring Models
29
Sep 21, 2016 11:57 AM
SPARKY01
Oct 23, 2010 08:21 AM
DocHarley
Dec 23, 2008 07:21 AM
