Shifter Bushings
Old May 1, 2011 | 08:29 AM
Shepherdboy44's Avatar
Shepherdboy44
Default Shifter Bushings
I noticed my heel/toe shifter was getting sloppy and was causing vibration sounds when I first start the bike cold. Went to order replacement bushings and was told by a friend that if there is too much slopp that you can ruin the transmission lever seal and cause a trans leak which would require removing inner primary to repair. Long story short, its pretty easy to replace the bushings and now shifter slopp is totally gone. Feels like it did when it was new. Just wanted to put that out to you guys to save you aggravation and costly repairs down the road. Bushings are cheap about 5 bucks for two of them, versus tearing out primary to replace the seal.
Old May 1, 2011 | 08:35 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Install a grease fitting on the shaft and there will be no need to replace the bushings in the future....
Old May 1, 2011 | 08:41 AM
Shepherdboy44
I didn't think of that. Great idea i may do in the future. Thanks. I put anti seize on the bushings when I installed them. Should be fine for a while. The original bushings had nothing on them. They were dry installed with no lube in there. No wonder they wore out in 19,000 miles.
Old May 1, 2011 | 10:01 AM
Punjabi Rider's Avatar
Punjabi Rider
Older bikes came with grease fittings but guess if HD can save few cents and sell you more parts.That noise can drive you crazy when idling.
Old May 1, 2011 | 10:29 AM
iwillfixthem4u's Avatar
iwillfixthem4u
Did the 10 k service on my 2010 SG yesterday. Took out the shifter shaft to check and lube it. I was also installed dry form Harley. I used white grease.
Old May 1, 2011 | 12:48 PM
jvvjvv's Avatar
jvvjvv
This is a great cure all.........stainless steel and like all Pringle stuff, well made.
http://www.pingelonline.com/eshifter...tm#shift_shaft
Old May 1, 2011 | 01:05 PM
reh13's Avatar
reh13
Nice idea...
Old May 1, 2011 | 01:30 PM
BLKBAGGER's Avatar
BLKBAGGER
It's real easy to install a zerk fitting. Pull the shaft drill, tap and screw it in.
Old Mar 12, 2020 | 03:13 AM
miketv84's Avatar
miketv84
Anyone know the part numbers for the shifter shaft bushings on a 2007 road king? Cant find it on Ronnie's part finder.
Old Mar 12, 2020 | 04:44 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Part #15 on the drawing, but they don't list it below, so it seems it's not available.
https://partsfinder.onlinemicrofiche...CASE%20HOUSING
