right front for your 06 PN 44136-00
rear for your 04 PN 41797-00
Diameter for both 11.50"
Bolt hole Diameter for both 3.25"
Center Hole Diameter for both 2.20"
But this is where the buck stops....Front Rotor Thickness .200" and the rear rotor is .230"
The minimum thickness for your rear rotor (and it is stamped on the rotor) is .205"
So what could happen is that you run out of caliper piston travel before pads make good braking contact. Please stay with the parts designed for either end of the bike. Your life could depend on it.
