FLHRS'04 upgrade to ABS
Old May 6, 2011 | 04:46 AM
Sazatornil's Avatar
Sazatornil
Default FLHRS'04 upgrade to ABS
Hi,
I'm thinking about upgrade my FLHRS 04 Road King Custom (no ABS) to ABS.
Does anybody know where can I find how to do that?
It's so expensive?
I need to improve my breaking system.
Thanks before hands.
Old May 6, 2011 | 05:25 AM
dawg's Avatar
dawg
Having you considered doing just the Brembo brake conversion? Some good write ups on that can be found here on the forum.
Old May 6, 2011 | 05:34 AM
mslater741's Avatar
mslater741
as far as i know it cant be done
Old May 8, 2011 | 09:42 AM
Sazatornil's Avatar
Sazatornil
Thanks!
I have looked for in google without success.
Old May 8, 2011 | 11:28 AM
cruise_carter's Avatar
cruise_carter
Unless buying a new bike with ABS, I heartily advise going out and practicing braking techniques. Practice, practice, practice.
This is the best way to prepare for situations.
ABS is not the only solution.
Ride safe..
Old May 8, 2011 | 11:31 AM
harley0711's Avatar
harley0711
Yes it CAN be done, just cost around $20K and I promise you - your bike will ride and look like new, lol
Old May 8, 2011 | 11:37 AM
Bushpilot's Avatar
Bushpilot
It can be done for your bike. but you are looking in the 4k range to get it done. Unless you can find a take off from a bike and build on it. It depending on the year you get donor from. you will need new CPU, wheels, rotors, and brakes. You will also need controler and all brake lines. It would be cheaper to sell the bike you have now and buy a used 2008+ with ABS
Old May 8, 2011 | 11:56 AM
Puttnutt24's Avatar
Puttnutt24
I installed Brembo's on the front of my "07, bolted right up and the improvement was night and day. Simple conversion. Calipers, rotors, master cylinder and clutch perch to make it all match. simple, all on ebay........
Old May 8, 2011 | 12:01 PM
crackercap's Avatar
crackercap
It is my understanding it can only be done by manufacturer, no bolt ons available. Even if it could be done I'm sure the cost would be pretty high...
Old May 8, 2011 | 04:28 PM
Jerry1834's Avatar
Jerry1834
You can't by the factory parts. I tried to add it to my 09 RKC...There is a big liability issue...I was told...So I traded up to 2011 with ABS....works great but need to get used to them a little.....Go with the Brembo's not as good as ABS but an improvement over the older style....Good Luck!
