I have been told by no less than 3 Tuners, to leave the Handle Bar switch On, and leave it alone as they have seen troubles with it if used to much.
I used it on my 98 wide glide from 98 to 2010 never a problem. On my 10 street glide I use the kill switch.
I had read that earlier bikes if the throttle was open when shut off it set that as zero. So I think many started using the ignition so the hand was not on throttle when turning off.
I use the ignition switch only. Why? To make sure my hand is not on the throttle for one. And, why take a chance, if the handlebar switch does go bad you're stranded. Rather wear out 1 switch than 2.
1. you should know where your hand is
2. i guess i'll just ride wheelies - better to wear out one tire instead of two
i use the kill switch. if it breaks, i'll fix it. if i'm stranded, i'll call AAA or hump it to a gas station. BFD.
My dealer recommended using the kill switch as he said if you don't use it it may become faulty.
My Dealer said the same thing and made a big deal about it too. Service guy said something about just using the ignition switch is hard on the newer bikes electrical system, it was all new to me.
