Kill switch use is the leading cause of dead batteries with the 50+ year old guys I ride with.
The root cause in that case is people who never LOCK the ignition switch after turning it off! If you aren't in the habit of locking it then the likelihood of leaving it on and running the battery down is much greater.
I guess the next poll should be do you lock your ignition.
BTW I always do, even in my locked garage.
i only use the key switch. those who use the emergency kill switch are likely used to metric bikes is all i can think. as far as i know only the younger techs at harley use the emergency kill switch, because if i have work done on my bike and go to start it, i get pissed off because i know that some rookie kid was riding my bike.
If I use the kill switch sometimes I forget to turn the ignition off. I have never run down the battery but it could happen. I quite frequently use both.
Most generally I only use the ignition switch unless I happen to park on an incline and have to leave it in gear then I use the kill switch, roll against the gear then ignition switch. Parked on level, it's left in "N"!
Reason: ...
I tend to use the ignition switch so I don't have to worry about leaving the lights on. Two people that I ride with have had dead batteries from hitting the kill switch and forgetting about the ignition switch therefore leaving their lights on.
I'm the one that gets pissed because my bike won't start. Finally figure out my kill switch was pushed. I know it wasn't me, I forgot the damn thing was even there... Of coarse the manual is gonna tell you you should always use the kill switch, it's there. Just like they tell you you should only use factory replacement parts, and only use HD oils and lubes..
