Radio wiring
Old May 16, 2011 | 10:55 AM
Snappykevin's Avatar
Snappykevin
Stage IV
Default Radio wiring
I'm trying to put in a powered antenna under the cowl. I would like to know the wire color for the amplifier power output from the radio or if the radio has an antenna power output, that would work also. Thank you in advance.
Old May 16, 2011 | 11:16 AM
wkl2546's Avatar
wkl2546
I have a J&M Amp installed and using the OEM HK Head unit. There's no output/trigger wire on either the Amp or HK unit that I'm aware of. As I see the issue, will need to somehow "find" an output/trigger that ONLY works in "AM/FM" mode. There's no sense in
activating a power antenna in CD/iPOD mode. Otherwise, you could just use any "power" output wire for a trigger source....
Old May 16, 2011 | 05:57 PM
cp1's Avatar
cp1
If it's just an amplified hidden antenna use the lighter wire.
Old May 20, 2011 | 02:38 PM
Snappykevin
Stage IV
I tried a Metra powered antenna and used the lighter power. this antenna is the biggest p.o.s. The reception is the same without my mast installed. Anyone know of a better option? Is the Harley one any good?
gearhead998
Audio Systems
May 12, 2013 10:54 AM
RidemyEVO
May 27, 2012 03:00 PM
Chicago Spike
Apr 19, 2009 08:38 PM
JDean
Jun 17, 2006 04:43 PM
SULLY 58
Dec 20, 2005 10:24 PM
