P1356 Code after Cam Swap
Old May 16, 2011 | 12:04 PM
scottdoege's Avatar
scottdoege
Default P1356 Code after Cam Swap
What could be causing a P1356 code after swapping to a Woods TW-666 cam. I also have adjustable pushrods a PC-V with autotuner and also swapped to new spark plug wires. This is on a 07 Ultra with a new D&D Fatcat muffler with a high flow air cleaner.
My check engine light comes on when accelerating hard and seems to go off when running at a constant speed. I tried to clear the code but it comes back. I did have a backfire when my rear pushrods were adjusted too high initially. I readjusted the pushrods and things seem to be running perfectly.
Other than that... my bike runs strong and I love the new power.
Any help would be appreciated,
Scott
Old May 16, 2011 | 12:09 PM
slothy's Avatar
slothy
http://www.*****************/forums/tw...stion-efi.html
see if that helps ya any
Coolhawg6622's Avatar
Coolhawg6622
Kinda plug wires?
Old Jun 29, 2011 | 03:35 PM
jrlaidle's Avatar
jrlaidle
I jusr swapped out plugs (NGK) and wiresn (Accell 8mm) on an 05 road king. I am also getting a check engine light under high revs high load. The light goes out at low revs low load. I tried swapping back to the original plugs. No joy. My next step will be to swap out the wires, but it is such a PITA, I am wondering how your problem was solved.
Thanks
Josh
Harleyrider1648
Apr 26, 2016 07:34 AM
Mr_Shake
Oct 18, 2015 05:26 PM
tripacer1
Aug 31, 2012 08:32 AM
jrlaidle
Jun 30, 2011 07:58 PM
mad34b
Mar 26, 2011 07:21 PM
