broken volume control
Old Jul 5, 2005 | 01:28 PM
finallyultra's Avatar
finallyultra
Default broken volume control
Hi Gang!
Anyone have an idea where I might find a (used?) volume control for the radio/intercom on my '00 Ultra?
I just took a 4400 mile trip, and somehow broke the darn thing.....probably in a panic grab for the horn button, but I'm not sure.
I took off the switch cover, and the volume controller is definitely FUBAR......a couple little pieces fell right out.
Also, if I have to buy a NEW one, can I get just the volume control, or do I have to get an entire set of left hand switches (horn, PTT, volume, Lt. signal)?
Thanks for the help!
Frank
Old Jul 5, 2005 | 04:17 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: broken volume control
You can just get the volume control from Harley. Good luck finding a used one.
Terry
Old Jul 5, 2005 | 07:13 PM
finallyultra
Thanks Terry...
I already have one on order at the dealer......just the one switch, so it'll be a cheap fix. My old Yammi required the whole switch set, which was almost $200!
Frank
Old Jul 5, 2005 | 09:30 PM
luvmyflhtcui's Avatar
luvmyflhtcui
You can replace just the volume switch without any issues. The **** just pulls off and you should be able to have the dealer order you just the switch and you can solder the new switch on your existing wiring, or just splice the new switch in. The service manual shows a detailed set of instructions of how to splice a new switch in and where to put the splices in the housing so they don't interfere with the rest of the switches.
Good luck.
[IMG]local://upfiles/494/AE11D5B0EB7942ED94FB4316656B5123.jpg[/IMG]
Old Jul 7, 2005 | 04:57 AM
finallyultra
Thanks Scott!
I'll refer back to your intructions when I get the new switch.
You guys are the best!
Frank
crazycanuck
Electrical/Lighting/Alarm
Apr 4, 2023 02:11 PM
bagger51
Sep 20, 2020 11:10 AM
Hey Man
Jul 7, 2018 12:15 AM
aviscomi
Jan 21, 2010 05:17 PM
EdwardK
Jun 14, 2009 08:07 PM
