bubbles on master cover
Old May 25, 2011 | 04:24 AM
karbar99's Avatar
karbar99
Originally Posted by lonerider2
Can someone tell me the part # for a black front master cylinder cover kit for a 2009 Ultra,
Thanks
PM Sent
Old May 25, 2011 | 08:01 PM
tnbillybob's Avatar
tnbillybob
Repair it quickly! Mine literally "exploded" brake fluid on my tank and inner fairing. Fortunately I was only a couple of blocks from my Harley dealer, and I had plenty of "detailing" supplies with me. Got'er cleaned up, and dealer replaced seal and "lid" under warranty, and told me if I had paint problems they would cover that as well. Culprit was the seal as identified in earlier reply. Good Luck!
Old May 25, 2011 | 08:25 PM
AbnMP13's Avatar
AbnMP13
The local stealership charged two of my buddies a butt-load of money to replace the cylinder, lever and lines for the same problem.
Old May 25, 2011 | 08:34 PM
Lost1's Avatar
Lost1
So does anyone make a chrome cover (not just the lid) for the entire master cylinder or do we have to buy a new chrome m/c from Harley for big $$$?
Old May 26, 2011 | 03:52 PM
Punjabi Rider's Avatar
Punjabi Rider
Originally Posted by Standard
HD would not cover mine. It will be the last extended warranty that I ever buy from them. Totally pissed me off.
ESP won't cover cosmetic parts but everything else has better coverage then HD factory warranty or at least that's how it is with my bike at the local dealer.
Old May 26, 2011 | 04:23 PM
Standard's Avatar
Standard
Originally Posted by Neckball
You say that like you read the extended service plan, it states this is a covered item and the dealer won't cover it?
Or have you read what is and isn't covered?
I called HD and went to dealers.
Old May 26, 2011 | 04:32 PM
Rickr01's Avatar
Rickr01
Mine was replaced under warranty because it leaked. The top was warped. it would spit out little dropplets of DOT 4 all over the paint. I'm glad I caught it. Dealer had another guy who thought the dropplets were from left over washing water. Speckled up his paint. DOT 4 is very very corrosive to paint and it takes no time at all to do damage from what I've seen. And regardless of what some may tell you, it is just as bad on powder coat.
Old May 26, 2011 | 07:19 PM
FLUltrarider's Avatar
FLUltrarider
I ride on cruise control a lot. I was noticing my right glove was changing color and my fingers were black after a ride. Turns out I rest my hand over the master cylinder as I want to be close to the brake and throttle, but not put my hand directly on the throttle. Turns out the master cylinder weeps brake fluid around the seal and it was getting wet from it. The cylinder works fine, so I can't really tell if it's porosiy on the gasket or if it's slightly warped or whatever. However, we all know what brake fluid does to paint and coatings.
Old May 26, 2011 | 07:35 PM
badblue's Avatar
badblue
I have had two covers replaced under warranty so far on my '07. One at around 20,000 and the last one at my 40,000 mile. Try a different dealership.
Old May 26, 2011 | 07:59 PM
cezariomaia's Avatar
cezariomaia
Originally Posted by Lost1
Mine looks like it has cancer, and has since it was a year old. Will eventually replace it with a chrome one. Funny, none of my Jap bikes ever did this...
Happened the same with mine rear master cylinder. My Suzuki's V Strom DL 1000 with the same age is just like new. Shame on HD!
target64
Jul 12, 2017 11:06 PM
Frédéric CM
Aug 5, 2015 07:14 AM
123easypay
Dyna Parts
Sep 28, 2012 04:07 PM
speedwaysteve
Jul 17, 2010 03:17 PM
harley1969
May 9, 2009 08:03 AM
