Jackpot exhaust question
Old May 25, 2011 | 10:32 AM
Jace's Avatar
Jace
Default Jackpot exhaust question
I just picked up a new 11 Ultra classic. I'm wanting to do something about the exhaust. Can I just install the jackpot dynotuned mufflers without doing the stage 1 air filter and dynojet?
Old May 25, 2011 | 10:52 AM
riff1006's Avatar
riff1006
Yes, you can. Are you just wanting to accomplish better sound? If you're trying to get rid of the cat and the heat, that won't do it.
Old May 25, 2011 | 11:13 AM
Gearhead3's Avatar
Gearhead3
Yes you can, but I wouldn't. The new bikes are already running too lean (for an air cooled engine) The narrow band O2's have a 'window' that they can compensate in. If, by adding slipons, you move out of this window, it can't compensate enough. All bikes don't respond the same to the exact same mods. I had an '07 Night Train that everyone said I could add slipons with no problem. Well, as it turned out, it pinged like B*tch after the install. I thought maybe it was a timing issue, so I mixed some 110 octane unleaded race gas in the tank and it still sounded like it was going to ratlle itself to death. Other guys did the exact same thing to theirs without any ill effects. Do it right the first time, get some type of tuner and put your mind at ease. (I did a Stage 1 with PC V to my '09 RG and the difference in the way it ran was nothing short of amazing) Most of the folks on here who have kept their bikes stock just don't realize how much better these new bikes run when given the proper amount of fuel.
Old May 25, 2011 | 11:16 AM
Jace's Avatar
Jace
Yes, I just want better sound. When I get some more funds I can add the other items
Old May 25, 2011 | 11:21 AM
TexasSG's Avatar
TexasSG
Will be replacing my Jackpots (slash-up) and OE headpipe with 4" Rineharts and Dresser Duals later this week if you're interested in some gently used ones.
Old May 25, 2011 | 11:22 AM
Rickr01's Avatar
Rickr01
To reduce heat and have that good Old Fasioned Harley sound, replace the entire exhaust system with a catless version. No Tuner or down load needed if you are doing just the exhaust.
Old May 25, 2011 | 11:28 AM
rg_dave's Avatar
rg_dave
The jackpots sound good but they are on the quiet side. I like the performance I get with the total stage 1 package with the dyno tuned jackpots. I also like the sound on the quiet side so they are perfect for me. They have a little bark when you get on the throttle.
Old May 25, 2011 | 04:12 PM
fabrik8r's Avatar
fabrik8r
Yes you can install just mufflers.
Old Aug 24, 2011 | 01:22 PM
FenderGuy53's Avatar
FenderGuy53
3.5" or 4" Jackpots? Stock head pipes with cat?
Old Aug 24, 2011 | 05:27 PM
StCRider's Avatar
StCRider
The best advise is to check with the exhaust manufacturers. They will tell you that the ECM will need to be re-mapped to compensate for the increased airflow.
But, you CAN just install the mufflers.
You CAN never change your oil.
You spent over $20,000 for you Harley, why be cheap and not get a $200.00 tuner.
seattlebob
Sep 1, 2017 03:18 PM
aje802
Exhaust System Topics
Dec 3, 2015 10:47 AM
Cardstang
Dec 29, 2014 04:52 PM
vanzant68
Jun 27, 2012 07:15 PM
timinfla22
Jan 23, 2011 02:32 PM
