Help with Cam choice
Old May 25, 2011 | 08:45 PM
onadraw's Avatar
onadraw
Thanks for the responses. I've got some info to work with.
Can anyone recommend a good tuner in NE Florida?
Old May 25, 2011 | 09:00 PM
pittz5's Avatar
pittz5
Originally Posted by mongomark
With the change in cams, the difference was very pronounced. Seat of the pants and on the dyno sheet. The bike no longer strained at higher speeds and the overall characteristics of the powerband improved. The stock cams are required due to EPA to be full of compromises. The high flow air cleaner, the exhaust and tune made a lot of difference but the cam change woke it up to the point that my clutch started slipping at full throttle in 6th gear above 90 mph. All I'm saying, the cams do make a difference.
+1, cam was the best thing ive done to bike money to power wise. I am NOT an SE kind of guy but really like the 255s I put in(used). Did adjustable pushrods, cam, inner bearings, and gaskets all under 400 and the bike has good low end grunt now. Worth every penny in my book. Exhaust/ air cleaner was twice that and the difference wasnt nearly as noticable. I would look at the S&S 551 if I were to do it again and I may still switch. Tman has cams that Ive heard nothing but good things about as well. Good luck, there are so many and everyone has their favorite!!
Old May 25, 2011 | 10:22 PM
Phat09flhx's Avatar
Phat09flhx
Very happy with my SE255's, pull top end off and run stock pushrods. Don't get any better than that.
Old May 26, 2011 | 09:55 AM
Buddy WMC's Avatar
Buddy WMC
Not in NE Florida, but a bit further South in Clermont (Minneola). Doc's Performance Tuning 352-404-6999. The man (Doc Weaver), is a master with the TTS and has a dyno on site. Been there, been to his school, got my T-shirt and tuned my 2011 Tri-Glide (lol). I am in SW Florida and really can't help you. Doc can do it and do it right, do yourself a favor and give him a call or Google up his website.
Old May 26, 2011 | 11:41 AM
iclick's Avatar
iclick
Good bolt-in cam choices for a stock (Stage 1) TC96 are few and far between unless you don't mind sacrificing low-end torque. Two that do well in this environment are the SE255 and Andrews 48H, both of which will enhance low-end and midrange torque, and to a lesser degree peak-HP. They are not stellar top-end cams and are designed to work well in a heavy bagger where power is desired where you are now, not after one or two downshifts.
I think most anything else will give you good midrange and top-end, how much depending on the grind, at the expense of some loss in the low-end. I can tell you that I've had the TC96/255 setup for >2 years now and I have no plans to do any more performance upgrades. There's more than enough power for my needs at <˝ throttle and <4000 rpms, but YMMV.
Old May 26, 2011 | 02:51 PM
HD Roamer's Avatar
HD Roamer
Default Hillsidecycle.com & Fuel Moto
Check with Scott here on forums as Hillsidecycle.com; he gave me excellent advice on my 04 RK and I'm very happy with the results. Fuel Moto has great reviews here on forums and their warranty surpasses others, including manufacturers (they add a full year +future download maps)...Unbeatable IMHO.
Old May 26, 2011 | 03:10 PM
lionsm13's Avatar
lionsm13
iclick; the guys at Fueling said that about their 525 cam too, that they disigned it for the bagger.
Old May 26, 2011 | 03:48 PM
Mike's Avatar
Mike
Totally agree. Also, call Bob Woods, he's happy to talk about his cams and has has been very generous with his advice and expertise.
Old May 26, 2011 | 03:57 PM
fripple's Avatar
fripple
SE-204 gets my vote for a bolt in 96" cam. I had good results and it was a night & day difference in power.
Timothy Rau
Jul 17, 2014 08:57 AM
cobalt07
Nov 28, 2010 07:19 PM
fuelmoto
Jul 21, 2010 01:05 AM
fuelmoto
Fuel Moto / Jackpot Mufflers
Jan 12, 2010 07:52 PM
mastery
Oct 17, 2009 09:43 PM
