Stripped Toe shifter
Old May 30, 2011 | 06:46 PM
roadglidedude's Avatar
roadglidedude
Default Stripped Toe shifter
My toe shifter fell I tightened it and it fell again
I took it apart on Saturday and it was stripped everything was closed so I was in a bind
I took them both off and turned my heel shifter forward
I want to replace both of those and the shifter rod that they connect to and the part that it connects to below the linkage
Can anyone help with part numbers?
I looked in my book and I can't find anything on these
Thanks for the help
Old May 30, 2011 | 06:59 PM
dawg's Avatar
dawg
33895-82D x 2
33709-82A
33718-82B
Old May 30, 2011 | 07:06 PM
1HarleyGuy1's Avatar
1HarleyGuy1
Man DAWG I get real jealous of you with the amount of info you got!!!
1HarleyGuy1
Old May 30, 2011 | 07:28 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
he needs to change his name to "threadkiller"
Old May 30, 2011 | 08:08 PM
BAMC's Avatar
BAMC
Default Other shift problems
Make sure to check the back connection to the shift linkage that goes into the primary. If that strips you have to remove a bunch of crap. Make sure that back linkage is tight. Cost me 700 to have it replaced on the road...I wasn't happy.
Good luck
Old May 30, 2011 | 08:22 PM
roadglidedude
Thanks Dawg
You can kill my thread anytime
Thanks BAMC
Old May 30, 2011 | 08:29 PM
bigdumbnoitall00
hope nobody took that wrong i mean it in the best way,he is always on the spot with good to the point advise.i think hes ended more threads than anyone in here.
Old May 30, 2011 | 08:52 PM
Paniolo's Avatar
Paniolo
That same thing happened to my bike on Saturday.
I was riding up to Big Bear, CA and when I went to down shift the toe shifter was all the way forward. So we took my extended heel shifter off, flipped it up and I ran that way the rest of the afternoon. I stopped by the dealer and got the shaft (pun intended) and started looking for another toe shifter. Then I remembered my OEM heel shifter. It was the same as the toe shifter except that it's threaded from the other side. I figure I'll just run an extra long bolt all the way through and secure it with a nylock nut.
That's a Harley for you.
Old May 30, 2011 | 08:57 PM
bigdumbnoitall00
its not just a harley thing in the 70" and 80"s i went through many shifters so many that to this day i carry a pair of vise gripps,they will kill whats left of the shaft but will get u home,even used them on a broken clutch cable clamped on the end and removed the clutch lever they sat right in the perch.
Old May 31, 2011 | 08:28 AM
Paniolo's Avatar
Paniolo
What kind of a bike was that on? It's happened to me TWICE on my Ultra. I've had other brands of motorcycles, and the ONLY other time was on one of my Kawasaki Police Training Bikes which experience more drops than a Sprint cell phone call.
e11charlie
Jul 2, 2020 06:48 AM
PFR-Captain
Jun 5, 2014 02:27 PM
DarkMatter
Jul 11, 2012 10:34 AM
WarLizard
Feb 13, 2011 01:53 PM
JacktheBagger
Oct 2, 2008 09:21 PM
