engine trouble code
Old May 31, 2011 | 07:05 PM
pbsdaddy's Avatar
pbsdaddy
Default engine trouble code
My check engine light came on and I ran the code. Says it's a clutch switch input short to ground.
I recently changed the grips so I'm thinking I pinched a wire when I put it back together. Could it be as simple as backing off on the bar clamp and pulling the wires out to ensure they are clear? Or is this an indicator of something more indepth, (costly)?
Old May 31, 2011 | 07:12 PM
JRBass's Avatar
JRBass
I would just do as you are suggesting first. check for pinched wire under clutch perch and see if you can clear it or if it cut the wire clean in half. Not sure on cost to replace.
Old May 31, 2011 | 07:19 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the switch is also pretty delicate might want to look at that too.
Old May 31, 2011 | 08:09 PM
dawg's Avatar
dawg
Along with checking what's posted above, the housing may not be lined up properly allowing the lever to completely make contact with the switch.
JT48
Jul 16, 2017 02:59 PM
heatmizer
Apr 8, 2017 05:53 AM
NickW
Jan 8, 2013 12:11 PM
SixSixRider
Jul 20, 2010 04:04 PM
amike
Nov 13, 2007 10:50 AM
