Air/Cleaner install Question ,,
Old Jun 3, 2011 | 10:41 PM
GEORGEW's Avatar
GEORGEW
Default Air/Cleaner install Question ,,
How Can I remove the Induction Module Bracket WITH-OUT removing the Gas Tank ?
Old Jun 3, 2011 | 10:52 PM
Tek74's Avatar
Tek74
Not sure what bike you have, but when I had the same issue when I did the a/c on my 2011 RGC. I ended up removing the seat and using a 2x4 to lift up the tank "just enough" for me to get my hex tool in to reach the two bolts holding the bracket in place. I think the bolts are loctited in, so be patient.
On a similar note, once the bracket was removed, I ended up hacksawing off the ends of the bracket at both shoulders, then reinstalling it so I could reclip the wire harness to the new a/c. I painted it black again before install too. Here is an April thread I started on the subject with pics.
https://www.hdforums.com/forum/touri...l-problem.html
Old Jun 4, 2011 | 03:04 AM
ThunderBueller's Avatar
ThunderBueller
Honestly, it's really not that difficult to remove the tank. Four bolts and the quick disconnect fuel line on the '09+ bikes.
Old Jun 4, 2011 | 04:26 AM
usmc3468's Avatar
usmc3468
Tank is really easy to remove. I have removed mine 2-3 times
Old Jun 4, 2011 | 06:34 AM
rusto88's Avatar
rusto88
Don't see the need to remove the tank. Just remove the bolts under the seat and jack it up a bit with a block of wood or something similar. Why risk scratching it by taking it off. Just my .02
Old Jun 4, 2011 | 09:08 AM
elauee1's Avatar
elauee1
You don't have to do anything with the tank use a short allen wrench but be carefully around the tank
Old Jun 4, 2011 | 09:23 AM
hotshoe's Avatar
hotshoe
I didn't remove the tank or lift it up either. Just used an allen wrench. It's a slow process but that's the only difficulty.
Old Jun 4, 2011 | 09:37 AM
elauee1's Avatar
elauee1
Short Allen and take ur time less than 5 min and it will be off my bike is a 2010 roadglide
Old Jun 4, 2011 | 04:13 PM
JohnScrip's Avatar
JohnScrip
My Allen keys weren't long enough, the ones for the 3/8" ratchet were too long. Took all of 90 seconds (if that) to prop up the back of the tank... Two bolts and a small chunk of 2x4.
And keep in mind that my mechanical aptitude is about as good as my ability to think of an analogy to having a really poor mechanical aptitude.
Old Jun 4, 2011 | 04:38 PM
'05Train's Avatar
'05Train
Short ball-end Allen or lift the tank.
