Exhaust Bracket
Old Jun 5, 2011 | 06:04 AM
dansflhti's Avatar
dansflhti
I used the cut off allen to loosen the first 1/4 turn and to tighten the last 1/4 turn,and the ball allen to remove the rest of the way.Another option is a Chapman set, a small ratchet with interchangable bits,but it was in my tool box at work when I needed it.
Old Jun 5, 2011 | 10:21 AM
Rickr01's Avatar
Rickr01
Originally Posted by djkolp
That's the nice thing about this wrench. No angle whatsoever. The ball Allen end is short enough to fit into the exhaust bracket bolts from underneath with no angle, and the handle is long enough to give you the torque needed to snug them tight.
DJK
I went to that web site, but could not find that particular wrench? Do you have their part number? Thanks.
Old Jun 5, 2011 | 10:28 AM
DPete's Avatar
DPete
I put hex heads with lockwashers on mine, just removed the heat shield to do so. Now I can get a 1/4' drive wobble socket on but they never got loose again. Locktite is good if you can get the holes clean enough.
Old Jun 5, 2011 | 06:39 PM
djkolp's Avatar
djkolp
Once you are on their home page just type "5530" into the search box, and it will bring up a page with this wrench listed as "Kastar Hand Tools 5530-Wrench, intake manifold"
Old Jun 6, 2011 | 05:31 AM
Rickr01's Avatar
Rickr01
Thanks, I appreciate the information. That will be a handy tool to have for more than just this application.
goldie
2014-2024 Touring Models
May 11, 2018 05:43 PM
kevdog
Aug 25, 2017 07:53 AM
live4rut
Sep 18, 2010 09:00 PM
ElectraLarry
Jun 13, 2010 04:56 PM
DougM
Jan 1, 2008 02:16 PM
