Question I have is can the stock bullet turn signals be reused with the passing lamps? Dealer says they are different and that I have to buy the other ones for correct fitment.
When the stealer put mine on, they said I couldn't use it......so........ But I'm sure alot of guys here are alot smarter than some stealers, and can do it!!!!
Did mine myself a few months ago - just need the new bracket kit (69818-06) and some bulbs. I bought the Halogen ones (68348-05). You un-bolt the signals and brackets, unbolt the signals from the stock brackets and bolt the signals to the new bracket.
Passing lamp bulbs. The SG passing lamp bracket kit comes with the brackets and the passing lamp housings and hardware but no bulbs. You pick the bulbs you want. Didnt mean signal bulbs. Like i said i took the oppotunity to get the Halogens which a lot of people upgrade their EG/C/CU to.
stealers are bad to lie, yes the stock turn signals will work as stated above, I know this because I used my stock ones when I installed my passing lamps. Pretty easy install I thought, all plug and play.
