bike chirps while accelerating
Old Jun 6, 2011 | 10:11 PM
Rucker00's Avatar
Rucker00
Thanks for the advise fellas. I think I'll be checking things out in this order: Lube (silicon) the rubber bumper and check the clamp on the exhaust; check whether or not the belt is loose; then the chain. The breaks look fine.
If anyone else out there has any idea of what it might be, stick it to this thread just in case the other guys who are experiencing can still get the info.
Old Jun 6, 2011 | 10:23 PM
vickers1's Avatar
vickers1
Originally Posted by Rucker00
I've read about the silicon spray on the rubber mount trick...what I noticed though is that those guys all had the problem at idol as well...mine is only on accel.
Also, I've only put 91 octane in, so I can rule out the gas idea.
Mine was on my left side muffler rubber only and only at idle. About drove me crazy. I'd be good till the lube wore off ...
Old Jun 6, 2011 | 11:17 PM
Fort Rider's Avatar
Fort Rider
Loose belt..........
Old Jun 8, 2011 | 01:38 PM
Rucker00's Avatar
Rucker00
Quick update: It's not the rubber bumbper on the exhaust mount. I took the rubber piece out yesterday, cleaned and lubed it, and no change at all. Looks like I'm on to the belt.
Anyone have any tricks on gauge the tightness of the belt without buying the HD tool?
Old Jun 8, 2011 | 03:17 PM
Phat09flhx's Avatar
Phat09flhx
Mine started doin it after I installed my cams, I figured it was in the clutch or compensator so I took a turn out of my clutch cable to loosen it a bit and it quit.
Old Jun 8, 2011 | 05:27 PM
JRBass's Avatar
JRBass
I just bought the tool. It was cheap. you will get different opinions here some do the twist method to gauge tightness and others swear on the tool. Search belt tightning and find the twist meathod if you want. Its something like only able to turn belt 3/4 of a turn or something like that.
Mine still chirps too BTW been to lazy to look for it. I know mine started when I put new Head Pipe and slipons on so thats where I guess I will start.
Old Jun 8, 2011 | 08:35 PM
BezerkoBob's Avatar
BezerkoBob
I've been battling this "chirp" for a while now. Mostly it has been the rubber slip on mounts. I'll buy some new ones and see if that helps when I do my 50K service. I'll also be checking everything else mentioned in this thread. As part of my 50K service and in an effort to eliminate this noise once and for all.
Old Jun 8, 2011 | 10:56 PM
Rucker00's Avatar
Rucker00
Last update: Success! It's fixed! Believe it or not, the dealer service manager new exactly what it was. I called the dealer today to see if they had a belt gauge in-stock. I was transfered to the Service Manager so I just explained everything to him. He told me to buy some "Poly-Lube" ($4.00) and put it on my belt. He said 90% of these types of chirps, that he sees/hears, is caused by a dry belt. After work, I picked some poly lube up, put it on the belt, and went for a ride...NO DAMN CHIRP!!!
Hopefully this helps you guys who are still chancing this elusive chirp.
Good Luck, thanks for the help...RIDE SAFE!
Old Jul 23, 2011 | 07:59 PM
dtwade's Avatar
dtwade
Mine started chirping today & loudly. I noticed it during decelleration. At first I thought it was another vehicle until it did it again at accelleration. I only noticed it between like 20 & 50 mph. I did run it up to 50 mph & killed the engine, then allowed to bike to slow down. It still did it. I figure this eliminates the possibility of egine/exhuast noise. I checked belt tension & it's gtg. Brakes are all new, less than 500 miles but I checked all the hardware. I'm thinking of trying this Poly Lube. The noise does appear to be comeing from the left side of the bike & at $4, it's not a gamble.
Any other ideas?
Old Jul 23, 2011 | 08:08 PM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by PistonPuller
Muffler brackets is where I would check. Might need a little lube there.
My '06 Road Glide had an annoying squeek/rattle.
It was the left side top muff bracket.I squeezed the metal bracket with Chanellocks to tighten up gap between the bracket and rubber piece.
