Pulling cruise control codes
Old Aug 28, 2011 | 12:13 AM
LEA2's Avatar
LEA2
6th Gear
Originally Posted by Harleypingman
Your '06 doesn't have the clutch/neutral lockout feature; HD introduced it to civilian bike with the '06 model year.
Carl
What could be the problem them if all the switch are working. Could I have a bad Cruise Module? Is a way to test it?
Old Mar 4, 2022 | 07:10 PM
110sheriff's Avatar
110sheriff
Stage I
Thanks for posting this. I've recently did the conversion to my 2011 flhtp. I'm unfortunately having issues though. Any input would be greatly appreciated.
Trouble shooting- I followed these steps and only get green red green when pulling the clutch. Nothing but green indicator on throttle, both brakes and siren. Red while driving.
To diagnose I used the instructions below
1. bike off, run/stop to run
2. push set/resume to set and hold.
3 with cruise on/off switch to on, turn on bike
4. cruise indicator light should be green, release set switch, light should turn red.
5. push to resume and release, light should turn green then red
6. push throttle closed and release, light should turn green then red
7. push rear brake pedal and release, light should turn green then red
8. pull front brake lever, light should turn green then red
9. on models with a clutch/neutral starter lockout, pull clutch lever, light should turn green then red whichever switch does not turn the light green, is your bad one.
if light will not turn green at all and you have followed ALL directions and tried multiple times, your set/resume switch is bad.
If light stays green even after releasing set switch, one of the dropout switches is stuck closed, usually the roll off throttle switch. unplug this and try again.
From the tests I was able to isolate the problem and replace the appropriate switch.
Regards Wayne
heavymetalthunder
Jul 21, 2019 07:51 AM
brschmidt
Dec 22, 2018 10:47 PM
ultra_bones
Electrical/Lighting/Alarm
Jun 15, 2011 04:59 PM
Duke02
Mar 3, 2011 08:14 AM
SubZer0
Apr 21, 2006 05:14 AM
