97 ultra help
Old Jun 7, 2011 | 05:19 AM
markdom's Avatar
markdom
Stage III
Default 97 ultra help
i have a problem with my 97 ultra classic , while riding i lose power engine quits and i have no lights . i coast to the side of the road and turn off ignition about a minute later turn ignition back on and bike starts normally seems to happen more often when outside air temp is above 80 degrees any thoughts would be appreciated
Old Jun 7, 2011 | 05:34 AM
dawg's Avatar
dawg
Couple things to check. I believe 1997 had a recall on ignition switch. Make sure yours has been done. Check your circuit breaker. Check codes, if you get "CKP/CMP out of range" could be either / or the crank and cam position sensors. Check your battery cable connections, could be a loose ground issue. I would start by pulling the codes first and see what comes up as that will guide you.
Old Jun 7, 2011 | 07:37 PM
markdom's Avatar
markdom
Stage III
Default 97 Ultra
Thank you very much for your suggestions. I will give them a try. Mark
Eddie's ride
Oct 4, 2013 06:27 PM
Ratrods40
Oct 21, 2011 02:43 PM
billybobshouse
Jun 11, 2010 07:43 AM
maineultraclassic
Aug 12, 2009 06:20 PM
NXHD
Apr 20, 2009 01:20 PM
