PCV Decel Pop ... Easy fix?
Old Jul 14, 2011 | 11:03 AM
vickers1's Avatar
vickers1
Originally Posted by RoadRich2010
How do you know what RPM you are getting the popping at if you do not have a tach?
If I didn't have a tach and knowing what I know now, I would go into my map and change all the zero throttle settings from approx. 1500 to 2300 RPM. Change the zeros to 15 and road test it. Like has been said, you can go as high as 50 without any adverse effects. I would only put in enough to get rid of the pop though.
Old Jul 14, 2011 | 11:07 AM
vickers1's Avatar
vickers1
Originally Posted by locodude
I kinda like the decel pop, am I just weird?
I love the scavenging sound when decelerating but I'm talking backfire and some of them loud. It's embarrassing to me.
Old Jul 14, 2011 | 01:13 PM
upstate tim's Avatar
upstate tim
scavenging sound +1
I dated a girl once who... oops wrong forum
Old Jul 14, 2011 | 06:12 PM
ke5rbd's Avatar
ke5rbd
Originally Posted by riff1006
If you can open your map on your laptop, go to each cylinder, and in the 0 column from 1750 up, change all those numbers from 0 to 15. You can increase or decrease by 5s and you can go as high as 50 without issue. Try it.....you won't hurt anything.
i noticed that increasing in this range also improves engine braking a bunch. It will get rid of the deceleration pop also if that is what is causing it.
Old Jul 20, 2011 | 09:22 PM
highhillbill's Avatar
highhillbill
ok im a newboobie at EFI how do you go into your map on a laptop?? Sounds a little Technical for a Carb Guy..??
Old Jul 21, 2011 | 06:57 AM
3/4 life crisis's Avatar
3/4 life crisis
Subscribed.
Old May 22, 2014 | 09:07 AM
brawner11's Avatar
brawner11
Originally Posted by smithbrl
That is what I did and goodby decel pop
Okay what did u do to get rid of the decel poping
Old May 22, 2014 | 10:12 AM
ThisIsMe's Avatar
ThisIsMe
Lots of good info here. I do have a bit of decel pop as well. Like others I do not mind most of it, but I am thinking it is a little to much.
Mine came off the dyno like this.
For the record how does adding fuel as such effect overall MPG? Anyone notice a difference?
Surprisingly my decel pops seemed to of gotten worse after replacing the fuel filter at 40K. Dyno was at 30k. Had another dyno guy tell me I should of had the fuel filter replaced before the 30k dyno. Not sure if it all correlates, but it does seem to be pooping more after the new filter. Or could be I am just imagining it.
Old May 22, 2014 | 11:00 AM
sg2007's Avatar
sg2007
Increase your ignition timing by 5 on the ignition map on the zero column ONLY, 500 rpm to 4000 rpm.See if that helps!
cubcake1
Jul 7, 2018 07:47 PM
118of1050
Dec 21, 2017 12:25 PM
bigmick23
Sep 10, 2011 09:25 AM
jmcd
Feb 10, 2011 11:58 AM
jeff.georgalas
13
Oct 17, 2009 09:19 PM
