Need help with lower engine rebuild
Old Jun 8, 2011 | 11:15 PM
DTTJGlide's Avatar
DTTJGlide
I think you're looking at 6-7 grand, make sure you add up everything you need to complete the build on your current engine, you'll need a SE comp on both. List price for just the 120R is $5495, you should be able to get it for 5 grand or less.
Old Jun 9, 2011 | 12:11 AM
bigskyroadglide's Avatar
bigskyroadglide
i just completed over the winter months a completed rebuild on an 07 road glide with 40K on the engine. Engine had a catastrophic failure, and busted the cases. I had revolution performance do the work, including replacing the cases, boring for a 110, welded and trued crank and a timekin bearing conversion. Believe me when i say, going this route was worth it. First, this is the smoothest engine i have ever had in a harley. At 3000 RPM, no vibration, power is awesome, with the 110. i looked into doing a 120 and total cost was going to be around 6 K. However engine is black and if you have a 07 roadie, you probably have a blond engine which would make you have to paint the trans case. In addition, the 120 is yours when its started and it does not have a welded and trued crank. so IMHO, your cost is the same, I ended up with 6K in my build, including new cases, all the machine work, heads, cylinders, pistons, cams, rotor and stator. With a build you do yourself you get what you want
my $.02
wild_one
EVO
Dec 27, 2013 05:18 PM
Just Dave
"The Florida Crew"
33
Aug 22, 2013 05:26 PM
Just Enough
Jun 23, 2013 12:59 AM
gunnert
Exhaust System Topics
Oct 21, 2009 10:06 AM
mplecha
11
Dec 18, 2008 08:56 PM
