Plastic Sheet/Spacer Tour Pak
Old Jun 9, 2011 | 06:40 AM
Avalanche_Mutt's Avatar
Avalanche_Mutt
I'd find some square tube and make some rails to raise it. Would be strong and cheap!
Old Jun 9, 2011 | 06:48 AM
shortride's Avatar
shortride
Here's some Black extruded Acetal plate material you can order custom sized for $128.
Old Jun 9, 2011 | 07:21 AM
1flhtk4me's Avatar
1flhtk4me
Being a machinist,I know that plastics are very expensive.
You could look for Polypro. plastic cutting boards at retail stores then cut them or laminate them to the required thickness.This will be a lot cheaper than buying from a plastic dist.
You can also paint them if needed.
Old Jun 9, 2011 | 09:04 AM
Harleypingman's Avatar
Harleypingman
Within the past two weeks, someone posted pics of a metal bracket sold by a vendor for mounting tour paks on police bikes to provide the necessary clearance. I didn't save the thread, so you'll need to use the search function to find it or simply scroll back and look.
Before I changed out to civilian bags, I used hard rubber automotive bushings sandwiched between a stainless steel washer on top and bottom to provide the necessary clearance with an Ultra tour pak mounted on HD's detachable two-up tour pak rack.
There's a local dept's FLHTP with radio box in the service dept. at my local dealer and I noticed it used tube shaped spacers to provide the clearance for the radio box. I'll stop by later today, and if it's still there, get a measurement.
Carl
Old Jun 9, 2011 | 09:52 AM
jberg's Avatar
jberg
Go back to your local plastics fabricator and get two sheets of 3/4" black HDPE (popular name is Sanatec) and lag them together with 1 1/4" counter sunk screws. HDPE will never hold paint so don't expect to be able to paint it. You could paint the screw heads to hide them. The material can be smoothed qnd beveled on the edges by scraping with the edge of a razor blade.
Old Jun 9, 2011 | 11:06 AM
gogogadgetbiker's Avatar
gogogadgetbiker
Banned competing forum owner
go to ww.mcmastercarr.com they have everything you need....
Old Jun 9, 2011 | 11:51 AM
assaultthesalt's Avatar
assaultthesalt
I'm not sure on your set up, but on my 06 RK Police, I had a machine shop make me some C channell out of thin sheet steel and then had that powdercoated.Was very cheap at $20 for 2 pieces plus $15 for the powdercoating.I went 3.25" high.I could have went 2.25" but that's ok, it don't look too bad.I'll try and get some pics up next week when I have some time.
Old Jun 9, 2011 | 01:33 PM
riteway's Avatar
riteway
Bobby (Gilbos440rt) is a member here.You might shot him a pm. He does work with billet aluminum and i bet he would have some good ideas for you and possibly make you some spacers.Great guy and member!!....
Alot of good ideas here,Personally my local Menards and Ace have a very good selection of hard plastic spacers and i would check there first. Good Luck and please post your findings and solution...... :-) ..................o~`o........................
Old Jun 9, 2011 | 07:14 PM
2001NightTrain's Avatar
2001NightTrain
Pingman I have searched and can not find the thread you're talking about.
Thanks for the ideas for all. I'm welcome to more. I have looked at extruded plastic but for the money...I may just go with the kuryakin adjustable set up if I can be certain if gives enough clearance on the 2009 & up bikes...mine is a 2011.
Old Jun 16, 2011 | 09:49 PM
assaultthesalt
Default Tour Pac spacers
Here's some pics of the C chanell that I had made and then powdercoated.Like I stated previously, they could have been 1" shorter but they work just fine.
Attached Thumbnails Plastic Sheet/Spacer Tour Pak-imgp1133.jpg   Plastic Sheet/Spacer Tour Pak-imgp1135.jpg   Plastic Sheet/Spacer Tour Pak-imgp1132.jpg   Plastic Sheet/Spacer Tour Pak-imgp1134.jpg
2001NightTrain
Jun 9, 2011 07:17 PM
2001NightTrain
May 7, 2011 08:50 PM
2001NightTrain
May 2, 2011 01:43 PM
Greg MacD
Oct 12, 2009 03:31 PM
flhtpi158
Jun 14, 2007 07:52 PM
