Oil Capacity Help
Old Jun 21, 2011 | 07:11 AM
Timholdy's Avatar
Timholdy
4th Gear
Default Oil Capacity Help
Guys,
Can't seem to find my manual and am about to change all three oils. I have an 04 Ultra , can you tell me the levels for all three?
Old Jun 21, 2011 | 07:29 AM
Arizona's Avatar
Arizona
Engine: put in 3.25 quarts with a filter change to start with. Run the motor for 30 seconds then let it sit a few min and check it. Add any if necessary. It'll probably take about 3.5 quarts. If you have an oil cooler closer to 4 quarts
Trans: one quart
Primary: one quart
Old Jun 21, 2011 | 07:30 AM
1flhtk4me's Avatar
1flhtk4me
Engine oil......3.5-4 qts.
Tranny..........22-24oz.
Primary.........32ozs.
Old Jun 21, 2011 | 07:35 AM
Arizona's Avatar
Arizona
Oops my apologies ref the transmission on an '04... I believe 1flhtk4me is right. Less than a quart on those 88" motors. My '09 is a quart.
My bad!
Old Jun 21, 2011 | 07:56 AM
speakerfritz's Avatar
speakerfritz
My bad!
check on the 09 again, heard there was a change on the primary and now it's 38 oz's
Old Jun 21, 2011 | 08:15 AM
Bob-n-Ohio's Avatar
Bob-n-Ohio
My 08 FLHTC repair manual calls for 38 oz in the primary. Even when I went to the dealership to buy the oils and o-rings the service guy told me only a quart is needed and is what they always use. I told him what the manual said and his response was they hadn't seen that. hummmm??????
I use as close to 38 oz as I can but make sure you can see the oil touching the inner primary parts.
Old Jun 21, 2011 | 08:16 AM
bdp's Avatar
bdp
My 08 and 11 primary held 38 ounces
Old Jun 21, 2011 | 08:25 AM
Arizona's Avatar
Arizona
Yeah I remember that for the '09. I was addressing his '04, but I did mess up on the transmission amount for his '04.
38 oz in the '09 and up is a PIA cuz you have to break into a second quart, but oh well.
Thanks for spotting me though... hadn't had enough coffee yet.
Old Jun 21, 2011 | 08:28 AM
Sharknose's Avatar
Sharknose
This thread demonstrates why you check the level visually and don't rely on measurements. :-)
claytonandson
Sep 9, 2024 03:02 PM
steve_h
Oct 1, 2012 11:46 AM
juanmanuelrojascavaliere
Sep 13, 2011 05:39 PM
Jaymac3772
Jul 12, 2010 04:11 PM
gammong
May 20, 2007 03:18 AM
