I didn't know about the hot water trick either, but I had no problems with mine.
I did have to dremel/shave the back trim of the volume button. The chrome switch was different from the black one it replaced. Made them look the same, and no issues since.
If it helps, you probably spent as much doing it yourself with several purchases of the buttons that if you had bought one button kit and paid the stealer....just sayin'! And you got the self satisfaction too.
Now that's the way I like to look at it. Possitive!
I really wish I had known about the hot water earlier!! I had to buy two sets due to destroying the inside of the cruise switch. Did you actually use the little copper shimmys? I gave up on those. They wouldn't allow the switch to fully slide on. I will remember the HOT WATER next time!
Do you use the copper peices? I helped my BIL do his on his SG after doing the set my my Softail, I thought you had to use the copper pieces, after fighting with them for way too long, we forced them on with the copper pieces PITA. It looked as if the black ones didnt have them to begin with. Luckily his switches still all worked. We are about to have to do it over as he is installing cruise control.
I like the black buttons. What did you think I meant? I put on black levers to match the controls. There's such s thing as too much chrome. The levers are easier than the buttons.
Well, they say once you go black you never go back. I never did go black though because I didn't want to be limited to only black but I've seen a few black ones that looked nice!
