Dresser Duals Knock
Old Jun 23, 2011 | 04:41 PM
Superbob's Avatar
Superbob
Default Dresser Duals Knock
Just had V&H Dresser Duals installed on my 11 Road King and it sounds like the pipes are hitting each other when at idle. Anyone else had this problem? Any solutions?
Old Jun 23, 2011 | 04:56 PM
VinnyM's Avatar
VinnyM
I just put a pair on with no problem,you can pull up the instructions on the V&H site but you should be able to see if they are touching anything.
Old Jun 23, 2011 | 05:00 PM
usmc3468's Avatar
usmc3468
No problems out of mine.....
Old Jun 23, 2011 | 05:22 PM
Redbeard719's Avatar
Redbeard719
No problems here. V&H did pack the wrong hardware from the factory. I worked with V&H customer service, and they took care of everything.
My issue wasn't pipes hitting each other, but rather my left S/O kept falling off the headpipe.
Old Jun 23, 2011 | 05:31 PM
Toypuller's Avatar
Toypuller
Check the floorboard mount on the right side.
Mine had the heat shield of the front pipe tapping it. It would only do it when it was fully warmed up. I used the spacers on the bolts, but still needed a small amount of clearance more. I shaved the heat shield below the floor board.
Old Jun 23, 2011 | 05:49 PM
Zimbob's Avatar
Zimbob
Your slip on's might have slid back and hitting the rear mount, Mine do it all the time. Sounds like they are playing "bash up" back there, but only at idle.
Old Jun 23, 2011 | 08:26 PM
Jkey's Avatar
Jkey
My only problem is the lower heat shield seems to drag in the curves quicker than the stock ones did.
Old Jun 23, 2011 | 09:12 PM
snip0721's Avatar
snip0721
also take a good look where the rear brake pedal pins to the master cylinder. steve
Old Jun 23, 2011 | 09:15 PM
user 8373900's Avatar
user 8373900
If they didn't put the spacers on the right floorboard bracket, they are hitting there and they may even hit then.I put on some 1" spacers on both boards.
Mark
Old Jun 24, 2011 | 09:53 AM
2009blackpearle's Avatar
2009blackpearle
Default my power duels
I had to take my power duel off to fix exhaust leak when i put back on the right floor board was tilted back and the chrome pipe guard was hitting floorboard mount-- just had to tillt floor board back and retighten. also your kit should have had 2 thick washers for floor boars, instruction are vague on where they go - i put mine under floor board mount to move it away from exhaust and it still hit when board tilted wrong way
bads1buell
Touring Parts
May 29, 2019 06:08 PM
Fuzzy-1
Jan 13, 2011 11:54 PM
turbo38sfi
Exhaust System Topics
Apr 19, 2007 09:56 PM
skratch
Apr 3, 2007 01:09 PM
TKanaley
Jun 11, 2006 09:25 PM
