blowing fuses
Old Jun 24, 2011 | 06:49 PM
mscharine's Avatar
mscharine
2nd Gear
Default blowing fuses
Hey folks, I have a 2010 Ultra Limited, whenever I plug in the GPS to the cigarette lighter in the fairing I blow a fuse, it takes about 10-15 minutes and the cigarette lighter itself works without blowing the fuse. The GPS works on the aux port in the tour pack, no problem there, has anyone else experienced this?
the dealer said that it checks out, it's very inconvient to run the cord for the GPS all the way back to the truck...and my 09 electraglide worked fine.
any input would be appreciated!
Old Jun 24, 2011 | 07:17 PM
lionsm13's Avatar
lionsm13
Don't have any great input other than to let the dealer deal with it.
It should be under warranty still I would think.
Let them fix it.
Old Jun 24, 2011 | 07:20 PM
duty2's Avatar
duty2
On my 08 Ultra, it blew the fuse in the GPS power cord. I checked the lighter plug and found that the hot wire was hooked up to the outside and the ground was hooked up to the center. I just switched the wires around and it works just fine. Check your plug and see where the hot wire is hooked up.
Old Jun 24, 2011 | 07:21 PM
Sam2010's Avatar
Sam2010
This has been posted many times so your not alone. So I am repeating what I have read I never had the problem.
1- check polarity on cig lighter.
2- replace cig socket with better one.
Old Jun 24, 2011 | 07:30 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
there is a slight difference between power outlet and ciggarette lighter socket.
Old Jun 24, 2011 | 08:14 PM
upstate tim's Avatar
upstate tim
Cig lighter draws much more current..
I bought a hd power outlet, not lighter, and it was pre wired backwards. Backwards compared to every other one in the U.S...
+ on the shell, - on the center button.
Lighters don't care what the polarity is.. Lots of other things do. Do yourself a favor and switch the wires if they're Bass Ackwards.
Lighter sockets are a little larger diameter.
Some or all non lighter sockets can't handle the current and/or heat.
Old Jun 24, 2011 | 09:04 PM
Buzz7's Avatar
Buzz7
4th Gear
I had the same issue during the Run To The Wall over Memorial Day Weekend. Blew the accessory fuse twice! I posted a question about the problem but didn't get any good replies. I searched this forum and some others with little luck. I did learn than an angle plug is better than as straight plug into the cigarette lighter as the plug can contact the the frame when the wheel is turned sharp. I have no problem with the GPS in my Ranger truck. Bike's cigarette lighter works like a champ, always heats up. Conclusion: Lighter socket is not meant to be used as a power outlet. I bought a power outlet with a 15A fuse, hooked it to the battery, ran the wire under the tank and have it in front of the tank. Haven't come up with a good way to mount it but I will. I have had the GPS plugged into my power port with no issues since.
Old Jun 24, 2011 | 09:18 PM
upstate tim
Some of my lighter powered stuff from years ago came with a sleeve that shimmed the plug so it would fit better in the larger socket. If not used the power would be sporatic from the loose fit. Aside from power being intermittent, you should never blow fuses.
Check for correct polarity.
Marine Glider
Jan 25, 2016 11:33 AM
see22ds
Feb 8, 2015 06:48 PM
KeeBee
Mar 10, 2012 08:26 PM
alandchris
Jan 18, 2009 07:22 AM
JeffreyB
May 20, 2008 04:01 PM
