OK before anyone flames me, I realize the following...
1. No I shouldn't be riding over 90.
2. I know it's not a sport bike.
3. I can't afford to spend more $$
Now the question/problem....
I was out riding the other day and had an urge to really open it up and see what happened. I get to about 75 in 5th, shift to 6th, climb fairly rapidly to 85 and it very slowly climbs to 89 or 90 and I can't get it to go any faster??? This leads to several trials at attempting to get it over 90 and the only time I did was when I was going down hill and then it only got up to 92. As a matter of fact, at full throttle, it actually slowed down until I let off the throttle a little.
Here's my set up. 96" stage 2 (SE 255 cam) SE tuner. I really just want to know if this is normal. I never attempted to take it over 90 stock or just as a stage 1.
Bummer! I have heard of this before. I believe it was on here, and it was an 09'RK.
I've seen my stock 88ci 06' Standard bump a ton on the gauge quick enough for me one time, and that was enough entertainment. I do wish the bike felt more stable at that speed but maybe one day! I don't ride up there, so it's not much of an issue.
I've read on this forum in other threads that you will achieve a higher top speed if you stay in 5th gear. I've hit 100 on my '08 SG with no problem but I don't remember if it was in 5th or 6th gear. Still felt like she had more to give, but I didn't need it.
My Road King passed the 100 mph test(that's good enough for me).
It will attain the speed limit in a flash.
It will out accelerate 99% of the cages on the road.
I'm good to go!
Riding conditions, and the map on your bike play a large part in top speed. I've had several top speeds on the same bike. even hit a buck twenty once, with a 40 mph tail wind.
