I finally decided what 21/16 wheels I want on my RK05. But I am not sure what width rim to get 3.0, 3.25 or 3.50. As I understand it I can only get a white walled tire in a 90/120 21. I plan to use a innertube to give the tire more width. So what width trim do you recommend and why? Thanks guys.
Mine's a 21x3.25 which was the only width available in the style I got. I think the stock wheel is 3.50. It took a little while to get use to being narrower.
Not sure what the problem with Vee Rubber is, but if they have the style of tire you want in the width you want, I'd give it a shot. It would be safer than shoving an oversize tube in a small tire, then stretching it to fit a wide rim. Bad idea in my opinion.
I run 3.5" on both my bikes with 21". Im going to get a vee rubber white wall when I get the cash. I haven't heard of any problems with them since the first batch that had dull white on them. From what I'm hearing they are a bright whitewall now
The rims don't come in for about a week or two. But I am going to pick up the 21 front first thing tomorrow. What PSI are all you guys using on your 21's.
I am running the older Vee rubber right now as well. the only "issue" was the antique yellowed white wall. I hit it with some white shoe polish and it looks perfect, but the new ones do have the bright white white wall.
I previously ran a 21x3 rim with a 90/21 white wall on it. It was fine, but there is a nice difference between the 3.5 with the 120 and 3 with the 90/21. On a bagger (I ride a softail) I would definitely do the 3.5. the bike is a lot heavier than a softail.
