hopped up my 103 a tad
Old Jul 17, 2011 | 08:03 PM
traveler's Avatar
traveler
Default hopped up my 103 a tad
Today I had the following installed:
SE 255 cams
SE slim/tapered adjustable pushrods
Gutted head pipe (cat removed)
Timken/Torrington inner cam bearings (replaced the cheapo stockers)
This along with the Klockwerk Super Saver mufflers I already had and some XIEDS
Runs HARD, strong lope at idle.
if moving in 1st gear and hit the throttle, will break the tire loose.
Unbelieveable power across the RPM range.
This, was after I removed the cover off of my intake so that it could breathe like it will when my Arless Ness Big Sucka 2 arrives in 2-3 days.
My Power Commander 5 will also be here shortly from Fuel Moto.
bike runs so hard, makes me wonder if I should jsut return the PC-V and save the coin. The XIED'S seem to be doing the job! :O
I highly recommend this. It is ALOT louder with the cat removed.
Work was done by Lyle Larson @ Speed Pro's in Rapid City. Absolutely top notch work, and I HIGHLY recommend him.
~Joe
Old Jul 17, 2011 | 08:12 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You might want to talk to Jamie about the Xieds myth. Your bike needs a fuel management system, and especially now that you have replaced cams, probably some timing and spark adjustments as well. So the PCV should do the trick, especially if Jamie pre-loaded the best-fit map for your setup. Jamie should be able to give you the info you seek.
Old Jul 17, 2011 | 08:13 PM
speakerfritz's Avatar
speakerfritz
thats sounds like the combo I am heading to....minus the power commander
Old Jul 17, 2011 | 09:07 PM
stratplexi's Avatar
stratplexi
Should make for one fun ride!
Old Jul 17, 2011 | 09:21 PM
alkrisma's Avatar
alkrisma
how much $$$$$?
Old Jul 17, 2011 | 09:40 PM
Suede Blue Man's Avatar
Suede Blue Man
Hell yeah! Bigger cams in your bike is like your best birthday even if it ain't your birthday!
Happy Birthday
Old Jul 17, 2011 | 10:35 PM
traveler's Avatar
traveler
PC-V from Jamie @ Fuel moto will be here either tomorrow or the next day.
After that is installed, I will later decide if I want to add auto tuners to it to make it "real time" precise.
Again, these cams are PERFECT for an FL.
~Joe
Old Jul 17, 2011 | 10:37 PM
traveler's Avatar
traveler
Originally Posted by alkrisma
how much $$$$$?
$650 installed before tuner. Approx 1K with a tuner and Big sucka.
WELL worth it.
~Joe
Old Jul 18, 2011 | 12:43 AM
Kingspoke's Avatar
Kingspoke
It doesn't take much to wake up the stock 103. A/C, pipe w/o cat, tuner, & cam and you got a bike that responds like it's suppose to and without the heat.
Old Jul 18, 2011 | 12:44 AM
klaybus's Avatar
klaybus
I too have a set of CVO 255 cams anxiously awaiting install. Trying to decide if I'm gutting the CAT or going with the Jackpot 2\1\2 head-pipes....Glad to hear the 255s your happy with. Do you have the 96 or the 103?
