Engine Light
Old Jul 17, 2011 | 11:03 PM
WNMORE's Avatar
WNMORE
Default Engine Light
This is a follow-up from a previous post. The engine light on my Ultra Limited 103" sometimes stays on after bike is started and sometimes goes out as it is supposed to do.
I checked the codes: the first two were under "P" which were 1510 and 2138. I think the next one was under "b" or "6", I could not tell which it was, but the code was 1155. The bike runs fine. When I first had this happen, I took the bike to the dealer, and they said everyting was OK and there were no current codes and the ones that appeared were "historic" codes. I do not know for sure if the codes were cleared.
Anyway, I cleared the codes and when I started the bike the first time after that, the light remained on. Not sure if I cleared the codes properly, I cleared the codes again and when I started the bike the next time, the engine light turned off and stayed off.
Does anyone know what these codes are and what I should do about them since the bike seems to be running fine and since the situation is intermittent?
Thanks.
Old Jul 18, 2011 | 12:51 AM
PistonPuller's Avatar
PistonPuller
P1510 Throttle actuator control limited
P2138 Twistgrop sensor correlation error
B1155 neutral switch input short to battery
Old Jul 18, 2011 | 04:49 PM
WNMORE's Avatar
WNMORE
Thank you.
Can anyone tell me what these codes actually mean, and in view of the history explained if these codes are "historical" or "current"?
Old Jul 18, 2011 | 05:40 PM
dawg's Avatar
dawg
PM sent
Old Jul 18, 2011 | 11:34 PM
WNMORE's Avatar
WNMORE
Thank you.
Will read when I'm more awake.
chizman
May 15, 2011 04:35 PM
WNMORE
Jul 19, 2010 12:00 AM
SE120RG
Jul 20, 2009 08:00 AM
scooby doo
May 18, 2009 07:59 PM
tennessee
May 3, 2006 07:53 AM
