Belt Dressing????
Old Jun 24, 2019 | 12:11 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Originally Posted by cprhed
You said you can get the squeek in neutral if you rev it up. Have someone else hold the throttle and get down on your hands and knees and crawl around it slowly to see if you can at least narrow down the area.
That being said, I haven't seen mention of this but the horn. That little thing is rubber mounted. Perhaps that it is.
But realistically the squeek happening even standing still when revved up means it isn't in the drive line. It is something squeeking due to resonate vibration. Look under your seat. Could be a plug that is rubbing somewhere.
I really like the baby powder idea for testing if it is the belt though. Way smarter than oil.
Hopefully the OP resolved his squeek issue since this is an eight year old 2011 thread.
Old Jun 24, 2019 | 01:43 PM
cprhed's Avatar
cprhed
Ha ha ha, dang, I so didnt see that
Old Jun 24, 2019 | 10:01 PM
hardheaded's Avatar
hardheaded
I know this is an old thread, but i've heard some mufflers make a squeaking type noise. The actual exhaust noise, not a rubber mount.
Old Jun 24, 2019 | 10:59 PM
CSMHOG's Avatar
CSMHOG
Old Jun 27, 2019 | 06:20 PM
dakotared's Avatar
dakotared
My license plate and/or license plate mount chirps, not enough to bother with however...
Old Jun 28, 2019 | 07:54 AM
mrfikser's Avatar
mrfikser
A couple of pieces of blue masking tape between the parts usually fixes those minor squeaks .
Old Jul 25, 2019 | 07:06 AM
ru4ragu's Avatar
ru4ragu
3rd Gear
Did you ever find the cause of the chirping ?
Old Aug 7, 2022 | 08:22 PM
TwinCamFan's Avatar
TwinCamFan
Stage I
Default same issue solved
check the belt - i had same issue - went into primary 3 times - turned out to be the belt was too loose and rubbing against the belt guard - very obvious rub marks -
Old Aug 7, 2022 | 08:44 PM
NorthWestern's Avatar
NorthWestern
I don't think he has that same bike that he had in that 11 year old post
Old Aug 10, 2022 | 09:31 AM
dfixit1's Avatar
dfixit1
Lightbulb
Squeeking in neutral,, hummm, have you changed the primary oil very recently? I have seen a condition where the primary drain plug was run in a bit too deep and just barely rubbing the clutch basket . If you have the drain plug that screws in from the side at the bottom of the primary cover.
