Which driver's backrest???
Old Jul 31, 2011 | 05:10 PM
rwtrick's Avatar
rwtrick
I use the HD backrest on my Road King. In addition to the adjustment on the backrest there are also 4 different mounting holes for the bracket that will move it either forward or back. It took me a little bit to get everything in the right position, but now that it is, it's great.
Old Jul 31, 2011 | 05:46 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
i got the adjustable and use it all the time ,on long runs its nice to change seating position every half hour or so.
Old Jul 31, 2011 | 06:07 PM
GliderX's Avatar
GliderX
The Moco P&A catalog says of the HD adjustable backrest "Separate purchase of compatible accessory seat....recommended for '09-'10 FLHX, FLTR, FLTRX, FLHR, FLHRC, FLHXX models". Has anyone used the adjustable backrest on an '09 FLHX with the stock seat?
Old Jul 31, 2011 | 07:40 PM
DeneFXDWG's Avatar
DeneFXDWG
FWIW I had them install a HD adjustable rest on my new FLHR and I can't really say anything bad about it. Great to adjust on the fly unlike the one on my Goldwing. Main shaft is a little long and I'm thinking of getting it cut down and powdercoated over the winter. Matches the rest of the seating and feels great.
Old Aug 29, 2011 | 06:40 PM
scootinz's Avatar
scootinz
Originally Posted by steelerdude1
I just went through the same thing. I ended up going with the mustang. Don't get me wrong, it works fine, but it does have it's short comings. First of all the adjustable height is worthless, no matter how tight you crank the set screw on the mount, it falls to the lowest setting when going down the road. I rigged a fix for that by wrapping duct tape around the stem. Second, it pulls out of the bracket vey easily, if someone wants to steal it, they can very easily. Ad last, none of the materials match the HD seats very well.
If I were to do it over, I would buy the regular Harley backrest. My buddy has one, and it matches seat perfectly, it can be manually adjusted, and no problems with it dropping.
When you say regular you mean the one without the cable? Anyone know if all the HD pads are the same? Will the same pad fit in either mounting lit (regular or the adjustable one)
Old Aug 29, 2011 | 07:03 PM
K Melancon's Avatar
K Melancon
I have the H-D adjustible and love it.
1) It's removable within seconds, just hit the latch and remove.
2) The height is adjustable, not much but adjustable without tools.
3) You can adjust it while riding on those long trips when you start getting stiff and want a new position.
The only thing I wish it had was a pouch attached to the rear to store items.
Old Aug 29, 2011 | 08:10 PM
2001NightTrain's Avatar
2001NightTrain
I have the "classic" Harley back rest and I love it. Never had the adjustable, but if the cables rubbing or plastic parts are an issue...I glad Ihave what I have. Once you find the position you like; I dontfind the desire to move the back reston the fly. I can move around on my seat if I need to if sore. Bun time I'm real sore it's usually time to stop for gas or restroom anyway.
Old Aug 29, 2011 | 08:29 PM
jberg's Avatar
jberg
Adjustable one works great. No issues with rubbing cables or cheap parts. Adjustable on the fly and the gas piston has a small amount of give making it feel sort of cushioned. I'm happy with mine.
Old Aug 29, 2011 | 08:48 PM
Hunter1979's Avatar
Hunter1979
I have the adjustable and love it. You can adjust while you are riding. It was worth every penny.
Old Aug 29, 2011 | 09:19 PM
Dionicio's Avatar
Dionicio
+1, the adjustable is the way to go!
