Engine idle?
Old Jul 31, 2011 | 05:06 PM
Reaper22's Avatar
Reaper22
Default Engine idle?
What should the idle be on an 08 street glide efi, and can you set it?
Old Jul 31, 2011 | 05:11 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
normaly 950-1000,some aftermarket tuner will allow adjustmet/ but no u shouldnt try and mess with it,lower idol can cause oil flow problems,and do not touch what looks like an idol screw on the throttle body,its a tps adjustment screw not idol if its off it will give the ecm fits trying to keep the idol, and its locktited from the factory.
Old Jul 31, 2011 | 05:12 PM
steelerdude1's Avatar
steelerdude1
Should be around 1000 RPM's. A dealer needs to adjust it via the ECM. If you are having high idle problems try this: with the kill switch on run, turn the ignition switch on for 10 secs, off for 10, four times. This reset should help. If not there is a download the dealer has to fix high idle problems on the 08 models. I think it's free.
Old Jul 31, 2011 | 05:18 PM
jackinthebox's Avatar
jackinthebox
Right around 1000rpms
Old Jul 31, 2011 | 07:38 PM
Reaper22's Avatar
Reaper22
Thanks guy's, I am between 950 and 1000 just thought might be a bit high, will do the reset just to be sure tho..
SA315B
Apr 9, 2017 10:38 PM
HD-EZ2NV
Oct 4, 2008 07:48 AM
rwj4709
Aug 11, 2008 06:27 PM
johnica
Jun 18, 2008 06:34 PM
profinish
Apr 24, 2008 08:14 PM
