Electrical problem
Old Aug 1, 2011 | 07:31 PM
young n bag'n's Avatar
young n bag'n
Default Electrical problem
Got an 09 street glide having touble figuring out why the brake light is stating on like you have the brake pressed in. then today trying figure thing out I noticed that my turn signal dont work or the horn. The bike starts runs fine and guages work is there a relau somewhere to check.
Old Aug 1, 2011 | 07:37 PM
dawg's Avatar
dawg
09's been having brake switch problems. Check the rear brake switch and make sure it's not melting, etc. Check the fuses as well.
Old Aug 1, 2011 | 07:49 PM
mkguitar's Avatar
mkguitar
did you by chance change out your bars or otherwise remove the hand controls?
1.) the front brake switch needs a shim put in place prior to removal
2.) lots of riders pinch wires when reinstalling controls to bars.
otherwise, it could be the conectors to the bar wiring harnesses...but the horn and front brake are on different sides.
mike
Old Aug 1, 2011 | 08:16 PM
RoadHog659's Avatar
RoadHog659
Recently had a similar problem. 1st check the rear brake switch to see if it's leaking brake fluid. If it is replace it - simple job, just remember to bleed the rear brake after changing out the switch. The turn signals and horn are on the same fuse as the brake light (at least they are on my 09 Ultra), so that is likely blown.
Old Aug 1, 2011 | 08:32 PM
young n bag'n
I pulled the wires off of the rear brake switch and the light stayed lit. I also checked the front brake switch and the shim was in there. I dont understand why my horn and turn signals went too
Belson_c
Sep 17, 2017 10:18 PM
Medicbearusaf
Jul 26, 2017 09:40 AM
hawwk
May 21, 2013 05:25 AM
tidefan60
Apr 23, 2010 01:45 AM
davandsarah
Feb 3, 2009 05:28 AM
