Rhino Lining
Old Aug 3, 2011 | 05:03 AM
ZBear's Avatar
ZBear
Default Rhino Lining
I am preparing to paint my 1994 FLHTC. The inside of the fiberglass bags are somewhat stained and I wanted to paint the inside also. The painter suggested coating them with Rhino Liner or something else rather than paint them. Anybody used this in their bags? Thanks, Bear
Old Aug 3, 2011 | 06:29 AM
cochon's Avatar
cochon
I never used it on my bike, but I lined the bed of my Tundra with it. This stuff is good. It is rugged, impervious to water, non slip. I think it is a good idea to line your bags with. Don't get it up too high, like where your covers make the seal, because Rhino Liner is rather thick and it might interfere with the opening and closing of the cover. Also may cause some problem where your bags fasten to the frame.
Old Aug 3, 2011 | 06:45 AM
mrmud4x4's Avatar
mrmud4x4
there is also other materials that are super tuff and have a smoother coat like "Durabak Smooth" and "Monstaliner" - google them.
Durabak probably has the most color options....
advance auto and autozone carry "Herculiner"..it is almost the same as the rough coat Durabak...when dry it is not smooth and it will scratch your skin....like very coarse sandpaper
I did the whole outside of my jeep in Durabak....now the branches come off on my paint and not my paint on the branches....can wheel anywhere...
Old Aug 3, 2011 | 08:10 AM
omgtkk's Avatar
omgtkk
I did it to my 2001 years ago. It wasn't RhinoLiner, but a different brand. There really isn't any benefit to using it over paint in a non-wear area like that, but if you do it yourself with Herculiner, like MrMud suggested, it should be pretty easy. If you do buy the kit you can also use it to coat the underside of your fenders. It provides some protection from large stones dinging your fender from the underside.
Old Aug 3, 2011 | 08:27 AM
tcfamy's Avatar
tcfamy
Check into zolatone paints. It has a kind of spatter look with a moderate, but smooth texture. We use it on small boat interiors and it is very durable. Comes in many colors. --Tom
Old Aug 3, 2011 | 08:30 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Good idea, I did my pickup bed years ago. The stuff is indestructible. Be carefull where you put it though, as mentioned earlier the sealing areas need to be clean.
Old Aug 3, 2011 | 08:38 AM
slothy's Avatar
slothy
you can add a reducer to make it smoother looking, so its not so rough. we did that on the bottom of my roadster fenders, slightly thicker then paint with a little texture.
Old Aug 3, 2011 | 08:41 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I think a carpet liner would be better. Keeps loose items from banging around and getting damaged.
Old Aug 3, 2011 | 08:43 AM
IAMSWUTIAMS
I think a carpet liner would be better. Keeps loose items from banging around and getting damaged. You can buy a pre-cut kit.
Old Aug 3, 2011 | 09:02 AM
Poochie's Avatar
Poochie
I've never used it on my bike...YET. I've been thing of doing a few trim pieces just to have a different contrast. I've used the Rhino coating on just about everything else, and it's great. The inside of my rag around jeep has been completely sprayed, and all the fender wells, door jams, and bed of my F250 has been sprayed. I've used the "Herculiner" stuff available at AutoZone several times and it works great as well, although it does not come out as thick. I repair lawn mowers for "mod-money", and usually every one I fix I'll use the Herculiner to coat the base and underside to keep them from rusting...comes out nice.
