need license plate bracket
Old Aug 4, 2011 | 02:52 AM
JS999R's Avatar
JS999R
Default need license plate bracket
I converted the old style bar turn signal lights on my RK to the RG/SG turn signals. Much cleaner look. I posted a picture of it and asked where I could get a license plate bracket that would mount below the signal light bracket, but attached to it. One that also utilizes the two fender bolt holes to attach it. That would mean the turn signal bracket and the license plate bracket would share the same mounting points, the two fender bolt holes. Actually the turn signal bar is HD part #68615-04. I found no provision for mounting a license plate bracket anywhere for this particular style turn signal bar.
Unfortunately I erased the bookmark an aftermarket company that sells the correct bracket, the info was provided by a forum member and I can't find the original post. I recall the license plate bracket cost $40, thats all the info I have for now.
Thanks, heres a couple pics of the mod.
Attached Thumbnails need license plate bracket-img_6784.jpg   need license plate bracket-img_6785.jpg
Old Aug 4, 2011 | 03:10 AM
av ultra's Avatar
av ultra
I think I got mine from softbrake
Old Aug 4, 2011 | 06:05 AM
smokindave's Avatar
smokindave
Don't think you will have enough clearance from the fender light for one like this from HD or Kury but, here is what mine looks like. Forgot to add.....What about a light on the plate? Most states require this.
Old Aug 4, 2011 | 06:15 AM
kyote's Avatar
kyote
I was looking for that bracket as well....
I believe the RG/SG tail-light lens has the Plate light on the bottom.. (someone correct me if I am wrong)...so he will just have to replace the lens
Yup..he was right..softbrake has em...
https://www.softbrake.com/shop/produ...dgroup=License
Old Aug 4, 2011 | 06:16 AM
stratplexi's Avatar
stratplexi
I am looking for the same thing. Here is a pic of one on a Limited I found on Fuelmoto website.
Old Aug 4, 2011 | 06:23 AM
BigDaddyMike's Avatar
BigDaddyMike
If you have the later (09) turn signal bar(with tag light) you can use the Kuryakyn curved bracket. HERE IS A LINK and they also make a bracket with a tag light if you do not have one.
And here is a pic of mine
Old Aug 4, 2011 | 11:51 PM
JS999R's Avatar
JS999R
Confirmed, it was the Softbrake site that has the relocator. It will fit my config and to take care of the license plate light someone told me Dennis Kirk sells an LED tail light with the light opening underneath it. Thanks
Old Aug 5, 2011 | 12:39 AM
getty30188's Avatar
getty30188
I bought 53702-04a to do the relocation.
jordan_nap
May 23, 2017 08:16 PM
IrIeSpringer420
Apr 1, 2015 06:43 PM
jmb79
Apr 2, 2014 04:57 AM
RiderX
Feb 21, 2013 02:30 PM
Jukebox
Nov 4, 2009 12:15 AM
